lathe question....
« back to Woodturning forum
Forum topic by jordanp posted 02-10-2014 12:05 AM 1805 views 0 times favorited 63 replies Add to Favorites Watch
View jordanp's profile
jordanp
1086 posts in 2181 days
02-10-2014 12:05 AM
Topic tags/keywords: lathe live center chuck craftsman
I just purchased a one way talon 4 jaw lathe chuck to put on my old craftsman lathe..
Any advice on how to remove this old live center? (Or whatever it’s called)
Edit
Just hooked it all up did a couple of practice pieces. Everything is looking good
-- J. Palmer Woodworks - Rockwall TX -I woke up this morning thinking “man, I really hope someone posted some soul scarring sh*t on LJs today.” -- - Billy
63 replies so far
View terryR's profile
terryR
7468 posts in 2549 days
#1 posted 02-10-2014 12:10 AM
Jordan is it a friction fit? Is there a hole on the opposite side of the head for a knockout tool? My Jet has a short bar with a knob on one end for lightly tapping such stuff out with a hammer.
-- tr ...see one, do one, teach one...
jordanp
#2 posted 02-10-2014 12:17 AM
I’m not sure there is a small hole that goes all the way through it.
terryR
#3 posted 02-10-2014 12:23 AM
?maybe a cheapo awl that fits through the visible hole in the drive center? and a little prying?
Edit…congrats on the OneWay chuck!
View mrg's profile
mrg
853 posts in 3240 days
#4 posted 02-10-2014 12:30 AM
Take a piece of wood or all thread a go in the hole at the other end of the headstock and pop the drive center out. You will need to give it a good blow with a hammer.
-- mrg
View mrg's profile
mrg
#5 posted 02-10-2014 12:31 AM
Double post.
-- mrg
View shampeon's profile
shampeon
1899 posts in 2424 days
#6 posted 02-10-2014 12:41 AM
Jordan: look on the opposite side of lathe head. There is probably a hole that goes through the lathe head that allows you to tap the center out from the back of the live center with a steel rod.
View waho6o9's profile
waho6o9
8539 posts in 2818 days
#7 posted 02-10-2014 12:44 AM
As noted above.
A knock out bar:
http://www.ereplacementparts.com/
jordanp
#8 posted 02-10-2014 12:53 AM
I took the pull off the opposite side and it appears to be a solid rod on that side.. going to look at it some more..
jordanp
#9 posted 02-10-2014 01:47 AM
Got it! Thanks everyone for the help.. Mr and wahoo had it right.. I it wasn’t solid.. knocked it right out..
View TerryDowning's profile
TerryDowning
1104 posts in 2358 days
#10 posted 02-10-2014 06:57 PM
jordan, that is a spur drive for turning between centers.
The threads on that spindle appear to be 3/4×16 so yo will need the appropriate adapter to match the threading on the chuck.
I have lathe similar to that (a 1939 Dunlap Sears second line after Craftsman) Feel free to PM or email me if you have any more questions.
-- - Terry
waho6o9
#11 posted 02-10-2014 07:01 PM
Does anyone use a washer between the adapter and the head stock?
View mahdee's profile
mahdee
4045 posts in 2008 days
#12 posted 02-10-2014 07:08 PM
I have one of those lath. It is missing a nut that once you unscrew, it pushes the center piece out. You have a locking device on the side that needs to be turned and pushed in to lock the pulley in place and stop it from turning.
-- earthartandfoods.com
jordanp
#13 posted 02-10-2014 07:16 PM
I have it mounted now. I had already purchased a 3/4 16TPI adapter for the Chuck. James Mine appears to have a large 1/4 thick washer between the threads and the housing where the pulley is located.. It was on there when i purchased it.
View mpax356's profile
mpax356
75 posts in 2733 days
#14 posted 02-10-2014 11:19 PM
Based on the picture I would say you will want to grind the edges of the spur drive before using. The edges should bite into the wood when struck with a mallet.
-- MPax, Atlanta
View Grandpa's profile
Grandpa
3261 posts in 2916 days
#15 posted 02-10-2014 11:44 PM
I got a 5/16 rod and just slide it through the hole in the shaft. I never tap it with a hammer. I slide it quickly and sharply. I catch the spur in my right hand. I think that puts plenty of force on them without crushing the end of the taper.
showing 1 through 15 of 63 replies
