veneering
Forum topic by Christopher Frank posted 332 days ago 137 views 0 times favorited 3 replies Add to Favorites Watch
View Christopher Frank's profile
Christopher Frank
2 posts in 678 days
332 days ago
Are there any general rules of thmb reguarding veneering over solid wood? for example: Is it safe to do? Do I need to Veneer both sides if the core is 3/4” thick? any advice or suggestions would be very appreciated.
Thanks -Chris
View Joey's profile
Joey
259 posts in 713 days
332 days ago
Try to avoid it. Solid wood moves, the best thing to do is to use a stable substrate if possible, ie. plywood or mdf. General rule when veneering is to always veneer both sides, this is to equalize pressure and prevent cupping or warping.
-- Joey, Magee, Ms http://woodnwaresms.com
Christopher Frank
2 posts in 678 days
331 days ago
Thanks for the advice, I did however do a little more research and found an article in Fine Woodworking regarding the subject. It had stated that contrary to popular belief you can veneer over a solid substrate so long as the grain travels in the same direction. I don’t think that I have much alternative in this case. We’ll see what happens.
View CharlesNeil's profile
CharlesNeil
159 posts in 768 days
331 days ago
i do it alot, and you are correct ,grain in the same direction, and above all and foremost , veneer both side’s,at the same time..otherwise it will cup on the veneered side and you will play the devil getting it corrected…
