Micro bevels--continuing the conversation
« back to Hand Tools forum
Forum topic by CharlesA posted 02-09-2014 04:52 PM 2871 views 0 times favorited 24 replies Add to Favorites Watch
View CharlesA's profile
CharlesA
3305 posts in 1704 days
02-09-2014 04:52 PM
Topic tags/keywords: question chisel plane sharpening
When I got my Veritas MK II honing guide, I read the instructions on how to put on a micro bevel. If you buy Veritas chisels, they come complete with the micro bevel. As I understand it, the main advantage is that the micro bevel is the sharpening bevel, so if you keep it sharp, one only has to hone a very small edge and that is much easier to keep up than the entire primary bevel. Makes sense.
Then I read Paul Sellers impassioned piece on why micro bevels are dumb. But as I read it, one part doesn’t make any sense to me. If the micro bevel is a larger angle, then it seems to me that edge has comparatively more metal than the primary bevel, so it is not weaker, but stronger. Am I making sense? If Sellers is correct on angle, then the actual angle at the end doesn’t make that much difference, it is really a question of whether or not the entire edge is at the same angle, or if the edge tip is a sharper angle.
Since I get confused easily, my planes now all have micro bevels and my chisels don’t (I changed my mind after doing the planes, in case you’re wondering), but now I think maybe the micros do make sense.
24 replies so far
View Tim's profile
Tim
3734 posts in 1868 days
#1 posted 02-09-2014 06:53 PM
I think the micro bevels came about because it’s easier to learn to get a very sharp edge that way with a honing guide than practicing the old school method Paul shows that as far as I can tell is how most of the old timers did it. I’m still trying to practice the method Paul shows, but man I can get a better edge faster right now with a honing guide. I just don’t have enough time for consistent practice. Once you’ve got it down though his method is probably more efficient.
I’m not real good at pictures but if you consider a convex bevel that has 30 degrees right at the end and then lowers to something like 25 compared to a blade with a 25 degree bevel all the way except for a 30 degree micro bevel, the convex bevel has slightly more metal along the bevel.
Of course neither needs to be that dramatic, it’s less difference in degrees than that, but it shows the concept.
View JJohnston's profile
JJohnston
1622 posts in 3198 days
#2 posted 02-09-2014 07:15 PM
No, you’re right. I don’t know why Paul Sellers doesn’t care for them, but he tends not to like jigs and modern contrivances in general.
I, for one, use the same Veritas honing guide you just reviewed, and I like it. I use the secondary bevel feature (maybe if you don’t call them “micro” they’ll be stronger) on everything.
-- "A man may conduct himself well in both adversity and good fortune, but if you want to test his character, give him power." - Abraham Lincoln
View Don W's profile
Don W
18606 posts in 2474 days
#3 posted 02-09-2014 07:40 PM
I think the premise is simplicity. I’m an advocate for what ever works best for you, but Seller’s point it this. You can spend $70 on a jig, or learn free hand. Learn free hand and suddenly its quicker, and you don’t need the $70 jig. Being its quicker your more likely to resharpen sooner. Sharp tools are happy tools.
The idea of a micro bevel is good at first, but the bevel grows. Soon you’ve got to regrind (whatever that means to you) or your micro bevel is your primary bevel. So spend time regrinding, or free hand and get back to work.
Then you can spend time flattening your stones, or you can just sharpen and get back to work.
My suggestion has always been to hollow grind to learn freehand. Hollow grinding make freehanding easier, and by the time the hollow grind is gone, you don’t need it any more.
View woodchuckerNJ's profile
woodchuckerNJ
1253 posts in 1541 days
#4 posted 02-09-2014 08:04 PM
My opinion, a micro bevel offers a firmer edge. BUT I am not using a micro on my chisels any longer. I have put a slight hollow ground on the chisels.
I also strop like crazy. many times I don’t have to sharpen, just re-strop. I have found stropping the is the biggest key to a sharp edge.
On my planes I will sometims use a micro bevel, but think of this, a micro bevel on a bevel down plane doesn’t change the irons angle. It does on a bevel up. I am only concerned with sharp, not how I get there. The sharper it is the better it is. As long as you don’t weaken the edge by putting a very shallow angle on the iron, all should be good, but different degrees.
-- Jeff NJ
View shampeon's profile
shampeon
1775 posts in 2090 days
#5 posted 02-09-2014 08:13 PM
A micro bevel has more material behind the edge than a straight or concave (hollow-grind) bevel, but a convex bevel has even more, and is easier to free-hand sharpen to maintain the same angle.
Edit to add in concave or hollow-ground bevel.
View knockknock's profile
knockknock
440 posts in 2080 days
#6 posted 02-09-2014 08:24 PM
Don W said: The idea of a micro bevel is good at first, but the bevel grows. Soon you’ve got to regrind (whatever that means to you) or your micro bevel is your primary bevel.
Ding Ding Ding
That is why I don’t use micro bevels, I don’t have a machine to regrind the bevel. I removed the factory micro bevel by hand (reground with a jig) on 2 pmv11 blades. It was not my idea of fun.
View Tim's profile
Tim
#7 posted 02-09-2014 08:25 PM
Thanks Ian, that was the picture I was trying to describe. As they say, a picture is better.
View jdh122's profile
jdh122
983 posts in 2724 days
#8 posted 02-09-2014 08:38 PM
I have the same Veritas guide and have been using micro-bevels on everything. I’ve recently started trying to freehand sharpen chisels and plan irons. I have been doing more work with axes, knives, gouges, drawknives and an adze, all tools that can basically only be freehand sharpened, and have been impressing myself with the freehand results, and decided to try on straight blades too. It immediately becomes clear why the microbevel is not recommended with freehand sharpening. I ground them off on a plane iron or two and found the freehand sharpening worked quite well. I’m not quite confident enough in my freehanding to get rid of all the microbevels yet…
-- Jeremy, in the Acadian forests
CharlesA
#9 posted 02-09-2014 08:40 PM
that pic illustrates why I didn’t understand the notion that micro-bevles are “weak.” I get why some don’t like it. Interesting to me that Lee Valley/Veritas, one of the biggies in the chisel/plane/sharpening world, are believers in micro-bevels.
Don W
#10 posted 02-09-2014 08:46 PM
Really? You’re in business to sell tools, and you can sell honing jigs, flattening stones, sets of stones, and a bunch of other Paraphernalia, or you can say hey, just free hand. I think their opinions might be slightly skewed.
CharlesA
#11 posted 02-09-2014 08:47 PM
They sell their highly regarded chisels, for example, with a micro-bevel as well—I was referring to that as much as the jigs.
View HarveyDunn's profile
HarveyDunn
328 posts in 1638 days
#12 posted 02-09-2014 09:30 PM
What Charles said.
I’m currently reading a book by renowned carver/instructor Chris Pye. His recommendation for carving tools? Micro-bevels.
View Bill White's profile
Bill White
4859 posts in 3867 days
#13 posted 02-09-2014 09:33 PM
Sharpening is kinda like sour mash. Whatever work for you is the way to go.
I use the micros on plane irons, and straight bevels on my cast steel chisels.
I use the Makita horizontal water grinder as well as a high speed 7” grinder. After studying some sites, I wonder how I ever get anything sharp. I guess that the leather strops and green compound save me from all the errors. :)
Bill
-- bill@magraphics.us
shampeon
#14 posted 02-09-2014 10:05 PM
I agree with Bill. We’re getting close to reigniting a holy war, so to maybe try to head it off, it’s important to note why Paul Sellers says you shouldn’t do a micro bevel. It’s because it’s easier to freehand a convex bevel, so you spend less time sharpening and more time working.
Any of the bevels will produce a sharp edge, so choose one way to do it among the bazillion ways, and let the noise of the debate fade away.
Don W
#15 posted 02-09-2014 10:08 PM
yea, this probably should be classified under the “religion” heading.
