Routing a Groove?
Forum topic by Richard Alexander posted 02-09-2014 12:51 AM 43040 views 0 times favorited 7 replies Add to Favorites Watch
View Richard Alexander's profile
Richard Alexander
78 posts in 3321 days
02-09-2014 12:51 AM
Topic tags/keywords: router
I’m still new at using routers and templates and am still learning my way around them. I’m working towards making a half-round challenge coin holder. The holder will have multiple levels. I’m trying to route a groove with my router. Looking around the forums, it looks like I may need to make a template for each level. I haven’t found anything on using the router table for a cut like this. Is their an easier way to do this with the table or are patterns the way to go??
-- Richard- Tulsa, Oklahoma
7 replies so far
View waho6o9's profile
waho6o9
8539 posts in 2817 days
#1 posted 02-09-2014 01:03 AM
http://microfence.com/circle-completebrbclick-detailsb-p-54.html
A little spendy but worth it for repeat ability and
precision work.
View Dallas's profile
Dallas
3599 posts in 2728 days
#2 posted 02-09-2014 01:11 AM
Use your router bit of choice.
Set the router fence to the amount of your relief.
Set the depth of the bit on a piece of scrap.
You aren’t using the center of the round for the dimensional setting, you are using the outside radius.
No need for a template or a pattern, just a round chunk of wood.
View gfadvm's profile
gfadvm
14940 posts in 2931 days
#3 posted 02-09-2014 02:15 AM
I’m not certain what the finished project should look like but Dallas’ plan will certainly result in smooth, consistent grooves.
View bondogaposis's profile
bondogaposis
5155 posts in 2592 days
#4 posted 02-09-2014 02:20 AM
Make a simple router trammel like this. There are many examples, they can be as simple or elaborate as you wish.
-- Bondo Gaposis
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1878 days
#5 posted 02-09-2014 03:31 AM
+1 bondo
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
Richard Alexander
#6 posted 02-09-2014 03:32 PM
Thanks for the suggestions. It looks like a router trammel/circle jig might be the easiest solution. Dallas, that’s pretty much what I did. It may be that I just need to learn some finesse, but it seems that a guide post/block or something would be needed to keep the cut in line. Otherwise, it can slide to the left resuilting in a straight cut (not along the radius).
117420 posts in 3818 days
#7 posted 02-09-2014 04:17 PM
There are a few ways to do this ,one way is to use a templates with a circle cut out on the inside or outside of the circle,or on a router table with an adjustable pin (similar to a circle cutting jig on a band saw) or with a “V” shaped fence on the router table. For the initial cutting of the circle I think I would use the tramel and then one of the other techniques to put steps inside the circle .
