Worth Wood Planes
« back to Hand Tools forum
Forum topic by antiquerob posted 02-08-2014 05:15 PM 8961 views 0 times favorited 7 replies Add to Favorites Watch
View antiquerob's profile
antiquerob
7 posts in 1536 days
02-08-2014 05:15 PM
Topic tags/keywords: planer
Came across a 9 1/4 inch Worth Plane in a lot of planes I purchased. I have never ran across this brand before and wondered if anyone has any background on the company or if the plane was rare or just another plane. It has a unique look and plan on at least giving it a good cleaning. Thanks in advance.
7 replies so far
View toolmike's profile
toolmike
37 posts in 1845 days
#1 posted 02-08-2014 09:28 PM
Hi,
Made by PEXTO. I have one of the Worth block planes, so the little information I have dug up is here…
http://workingbyhand.wordpress.com/2013/12/12/the-clone-wars-part-iii-a-tale-of-three-planes/
Just one of the “clones” made by Pexto for other companies. It’s amazing how little info there is out there in the electronic world.
regards,
Mike
View bandit571's profile
bandit571
19721 posts in 2647 days
#2 posted 02-08-2014 09:51 PM
Had a few Worth planes
They can be made to work. Frog is the main problem area on these planes.
View Don W's profile
Don W
18685 posts in 2532 days
#3 posted 02-09-2014 07:43 PM
I see quit a few around here and on ebay. I steer clear. I don’t like the stamped frog. I’m not sure if they ever made a better plane or not.
Smitty_Cabinetshop
15280 posts in 2583 days
#4 posted 02-09-2014 07:46 PM
Stamped frogs are the Debil.
10258 posts in 3612 days
#5 posted 02-09-2014 08:23 PM
I think I have a WORTH plane iron somewhere.
PEXTO chisels are pretty good. Maybe the plane iron
is too.
bandit571
#6 posted 02-09-2014 09:42 PM
Once I got the iron flat and sharp, iron was great. Chipbreaker fits ONLY Worth planes, same with the lever cap. They are both at least 1/2” shorter than other brands.
bandit571
#7 posted 02-11-2014 11:20 PM
Other things about these planes
They are HEAVY
The handles are large, but comfy.
Do NOT even loosen them bolts holding the frog, they are a ROYAL PITA to get back in place.
Soles need work. Usually these planes were used HARD, with little upkeep. Soles get worn a bit. Usually right on the toe/nose areas. Plane was slapped down onto the work, a LOT.
Lateral adjusters: Loose, but usable, watch doing any rehab to the frog’s face, or you will make the lateral worse.
Unlike better planes, the yoke is just steel, and can be tightened up to the wheel.
Bolts for the handles: these are bolts, one piece. I have seen up to three washers under the heads of some, just to keep the handles tight. Might add a lock washer, too.
Planes were made for “Joe Handyman” to be used and abused. They were made for hard work, not a fine woodworking shop. These went out into the jobsites.
