A dumpster dive find - director's chairs
Forum topic by agroupergirl posted 02-08-2014 05:14 PM 1096 views 0 times favorited 4 replies Add to Favorites Watch
View agroupergirl's profile
agroupergirl
2 posts in 1598 days
02-08-2014 05:14 PM
First, I would have to say I am not a woodworking professional but need advice. I have a table that I bought for about $10.00 at Goodwill. It ended up being Mahogany and it turned out beautiful. I used the Minwax oil based red chestnut stain on the table and their satin polyurethane for the final finish. I have two directors chairs that were a dumpster dive find and I believe them to either be white oak or red oak. I have stripped, sanded, and stained one of the chairs. I have applied the same Minwax stain to the chair; however, I cannot get it even close to as dark as the table – I have applied the stain in three different applications. I want to make it as dark as possible to match the table. The chair seems to be older (it has rivets and some of the grain is not very visible – even w/o stain or poly) and I would have to admit that it felt like I could not pull all of the old poly out of the wood – it has a very waxy texture even after sanding. I am considering trying one last staining application to the chair before poly in an attempt to darken it one last time. My questions are:
1) Will I ever be able to get red or white oak as dark as mahogany?
2) If I am able to stain it as dark, would you recommend another color – I do want to keep the red in the stain?
Thank you for any help any of you can provide.
-- agroupergirl
View crank49's profile
crank49
4032 posts in 2998 days
#1 posted 02-08-2014 05:35 PM
You may have to use a dye; or fume it if it is oak.
An option, if you don’t feel like you got the finish off is to strip it.
View SuperCubber's profile
SuperCubber
1027 posts in 2312 days
#2 posted 02-09-2014 01:42 AM
Staining it again probably won’t do a whole lot. Stain doesn’t penetrate like a dye does. Like crank said, a dye would be a better option to darken it up.
-- Joe | Spartanburg, SC | "To give anything less than your best is to sacrafice the gift." - Steve Prefontaine
agroupergirl
#3 posted 02-12-2014 12:59 PM
Amazingly I tried staining it one more time and it took just a tidge more – it is now kind of a walnut type color with a tiny bit of red. I am going to call that done and then put the poly on it. Thank you for the replies.
-- agroupergirl
View dhazelton's profile
dhazelton
2771 posts in 2324 days
#4 posted 02-12-2014 02:16 PM
If you want oak to look like mahogany with chestnut on top you first need to make the oak look like mahogany. If you haven’t put the poly on yet gett some dark mahogany stain and give it a wash of that as well.
