How many clamps for a glue up?
« back to Joinery forum
Forum topic by Greg In Maryland posted 02-08-2014 01:34 AM 5107 views 0 times favorited 23 replies Add to Favorites Watch
View Greg In Maryland's profile
Greg In Maryland
553 posts in 2931 days
02-08-2014 01:34 AM
Topic tags/keywords: clamps
Hi all,
I have to glue up several panels—approximately 24×40 inches and 24×24 inches. I am tired of using pipe clamps and screwing up. So in hopes for getting better results, with fewer hassles and hopefully much lower stress, I purchased five Jet parallel clamps.
I know, I know, you cannot have too many clamps, but at $60 per, I really cannot afford more clamps. So, will five parallel clamps suffice for a panel that is 24×40 inches? I can always throw on some bar clamps or pipe clamps, but I want the parallel clamps to do most of the work.
Any thoughts or recommendations would be greatly appreciated.
23 replies so far
View CharlesA's profile
3310 posts in 1730 days
#1 posted 02-08-2014 01:36 AM
I prefer parallel for panels as well, but it might be helpful if you could explain why the pipe clamps screw it up for you.
Gerald Thompson
892 posts in 2167 days
#2 posted 02-08-2014 01:58 AM
I have never had a problem with pipe clamp unless it was my mess up. I invariably use cauls to keep it all flat. Go to Mike’s site and you can learn how to make your own cheaply, easily and fit for a life time of use.
You will have enough claps for your project. Remember to dry fit and clamp to test things first.
-- Jerry
View pmayer's profile
1022 posts in 2998 days
#3 posted 02-08-2014 02:15 AM
It depends how wide your boards are. The wider the boards, the fewer the clamps needed. Picture the clamping pressure projecting onto the panel at roughly a 45 degree angle to the clamp itself. if you put your clamps into position and sketch these lines onto the panel you can get a sense of where your clamp pressure coverage will be.
I would typically want more than 5 clamps on ta 40” panel. I suggest using the pipe clamps in addition to your new bars. Don’t over tighten then and you shouldn’t have any problems. If you are having problems, I would also suggest gluing up these panels in two stages. That way you can focus your attention on flushing fewer joints, and you will likely have better luck with this approach. Plus, if you have a portable planer you can run each smaller panel through the planer before gluing up your final panel size, and that way you only have to sand one glue joint flush.
-- PaulMayer,
#4 posted 02-08-2014 02:20 AM
Cauls really are a key. In addition to the link proved above, I’ve found this one from highland woodworking to be really helpful in making and using cauls.
View waho6o9's profile
8130 posts in 2510 days
#5 posted 02-08-2014 02:24 AM
View gfadvm's profile
14940 posts in 2623 days
#6 posted 02-08-2014 02:26 AM
Jerry, That’s a great link. I thought there was a way to make cauls with a jointer (or did I imagine that since I’m not much of a hand tool guy?)
View alysonsdad's profile
10 posts in 2573 days
#7 posted 02-08-2014 04:24 AM
how many clamps do you need? more than you could ever buy! lol
-- Illegitimi non carborundum
View paxorion's profile
1107 posts in 1978 days
#8 posted 02-08-2014 04:40 AM
I’m still curious as to why pipe clamps aren’t working well for you.
-- paxorion
View Bluepine38's profile
3379 posts in 3018 days
#9 posted 02-08-2014 05:31 AM
I am curious about the pipe clamps also, I started using pipe clamps in high school shop and used them
since, because I could not afford better clamps. I now have more clamps, but still use the pipe clamps
quite a bit.
Greg In Maryland
#10 posted 02-08-2014 05:37 AM
Thanks everyone for the replies. Excellent information, as always.
In a nutshell, it’s all about juggling. By that I mean ensuring that the black Iron rods don’t touch the wood, keeping the clamping pressure centered on the thickness of the wood, ensuring that the clamp pads don’t fall off (hot glue does not work all that well) or the pads break or get in the way, all while ensuring adequate clamping pressure, correct alignment, etc., etc. I can get plenty of clamping pressure, but control and finesse is lacking.
Additionally, the f-style clamps I have are Harbor Freight specials and just are not robust enough. They twist and bow, and have their own set of problems.
My hope is that the parallel clamps will eliminate a few of the complexities, and let me focus on the important aspects of glueups.
Thanks again for all the thoughts and comments.
So, five Jet Parallel Clamps are either with me or on their way to me.
View JAAune's profile
1780 posts in 2250 days
#11 posted 02-08-2014 05:45 AM
We mostly use parallel clamps now but it’s for speed and not for joint quality.
If you want to get maximum effect from pipe clamps open them up just a little wider than they need to be for the glue up then loosely place a piece of packing tape across the pipe wherever it is likely to contact glue. This allows you to press the boards tight against the pipe without black spots happening. Don’t press the tape in place because that makes it hard to remove later on.
This really helps keep the panels flat. Adding a few clamps across the top to balance the ones on the bottom will also help.
Regarding the number of clamps needed, it’s generally safe to assume that the pressure will spread about 45 degree angle from the clamp face. To ensure there are no problems just make sure you have enough clamps to allow the pressure areas to overlap. The wider the boards being glued, the less clamps you need. I’ve gotten away with far less clamps on some glue ups but it does create a risk of gaps showing up after the dried glue is scraped away.
-- See my work at and
#12 posted 02-08-2014 05:26 PM
I agree with the comments suggesting that pipe clamps should work. I have both pipes and parallel bars, and get good quality results with either. There are reasons that I reach for each of them in certain situations, but for gluing up panels I will use either one with equal confidence. Also, I don’t believe that cauls are necessary for gluing panels, particularly if you glue up in stages. Having said that, I know that many people love them and they can help to overcome some technique problems so they might be one means to solving your problem.
A couple things that might be helpful;
- Many panel glue up problems are caused by distortions in the stock. If you aren’t getting your stock perfectly flat with square parallel edges, you can’t fix those problems with clamping pressure. Take your time at the jointer. If you see any gap or misalignment during dry fit at the glue table, take the offending board(s) back to the jointer.
- Another common problem is boards moving around under clamping pressure as a result of too much pressure too quickly. Tighten the clamps in two phases. First, just tighten them enough so that there is good contact across the joint, and force the joints flush. Then, after the glue forms its initial tack (5 minutes or so, depending on which glue you are using) tighten them further. If you crank to full pressure right away (without cauls), you will have a hard time keeping things aligned.
- As I mentioned in an earlier post, gluing up a panel in multiple stages makes it much easier to get good results. Glue up two separate panels, plane each one, joint the two glue edges, and glue them together. You will reduce your hand sanding time by a lot, and produce a lot less dust in the process. Don’t skip the step of re-jointing the glue edges for your final panel glue-up, as gluing up the stage 1 panels can distort the edges enough to cause problems with your final glue-up.
- Using a glue with a bit more open time like Tightbond 3 can help a lot with larger panel glue-ups. It gives you a couple more minutes to force all of your joints flush and makes the process a bit more leisurely.
- If you are having a hard time keeping the panel positioned properly on the pipe clamp to center the force (and it sounds like this is part of the problem), just push the panel down flat to the pipes. If you alternate clamps on top and bottom, your panel you will offset any distortion. If you glue up the panel in stages any staining will easily come out when you plane the sub-assembly. If you get the panel out of the clamps soon enough, staining shouldn’t be much of a problem anyway. If you have one face of the panel that will not be displayed in the final project, then put that side down in the clamps, and suspend the top clamps with just a bit of clearance to avoid staining.
-- PaulMayer,
View AlanBienlein's profile
159 posts in 2607 days
#13 posted 02-08-2014 06:39 PM
I only use pipe clamps or my wilton bar clamps. I’ve tried the bessys and they sre just way to fussy and over priced.
As for the black marks I don’t have that problem but I also don’t believe in using the black pipe. Nothing but the galvanized 3/4” ridgid electrical conduit as it’s less expensive than the galvanized 3/4” water pipe. I never never ever had a problem with slippage using this pipe and no black marks.
As for holding the clamps I made me some stands out of scrap plywood and the wonderful thing about doing it this way is there is no need to clean off the work bench to do a glue up.
As you can see there is no need to clear off the work bench to do a glue up using these style of clamps.
117030 posts in 3510 days
#14 posted 02-08-2014 07:10 PM
Lots of good suggestions , I find most problems with panel glue ups stem from few mistakes people make, one is that people don’t alternate their clamps (one on the bottom and on on the top) another area is having you clamps uneven (one side of clamp being much higher than the other end) and not having the clamps parallel across your panels making for unequal pressure that can cause distortion of your panel. Another area is when using pipe clamps don’t let the pipes touch your wood (no black marks) an lastly don’t need a lot of pressure(some people tighten the clamps as tight as they can (another area that can cause distortion of your panel). Even though parallel clamps are nice to have you can get good results from almost any clamp that will give you enough pressure to glue up panels.
-- wood crafting & classes
View jdh122's profile (online now)
992 posts in 2750 days
#15 posted 02-08-2014 08:24 PM
Here’s a short finewoodworking video that shows how to make cauls with a jointer:
-- Jeremy, in the Acadian forests
