Are T-Track components and accessories interchangeable among brands
Forum topic by HarveyDunn posted 02-08-2014 01:24 AM 2481 views 0 times favorited 16 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1816 days
02-08-2014 01:24 AM
T-Tracks and accessories interest me. So far I’ve seen them offered by/at:
Eagle America
Incra
Kreg
Peachtree (T-tracks USA seems to be the same company)
Rockler
Woodpecker
Any important suppliers that I’ve missed? I know there are other retailers (like Woodcraft) but I’ve left them off the list if they appear to be simply selling the Incra, Kreg, etc. product lines with not much that is unique to them.
I was wondering if any knows if the components and accessories are interchangeable among the different suppliers…or if once you start with a brand you are locked in.
All other pieces of T-track related advice will be greatly appreciated.
16 replies so far
View CharlesA's profile
CharlesA
3334 posts in 1883 days
#1 posted 02-08-2014 01:33 AM
Another source is Lee Valley. Someone may have a more complete answer, but for me the big decision is between t track that will accept 1/4” bolts and those that only accept t bolts. Lee valley won’t do 1/4”, but incra and Kreg (I think) accepts 1/4”.
View jimr1cos's profile
jimr1cos
31 posts in 1971 days
#2 posted 02-08-2014 04:56 AM
I recently bought from Incra and Kreg; they both accept 1/4 in but the heights are different.
Jim
View ksSlim's profile
ksSlim
1281 posts in 2975 days
#3 posted 02-08-2014 05:03 AM
Short answer, no!
look for spec drawings, different height, outside profile, (hump on outside), hardness.use
As was already answered, several use or accept .250 hex head bolt, others require T-bolt.
-- Sawdust and shavings are therapeutic
View lepelerin's profile
lepelerin
495 posts in 2410 days
#4 posted 02-08-2014 05:57 AM
FYI Freud makes T Track too.
View BJODay's profile
BJODay
526 posts in 2028 days
#5 posted 02-09-2014 12:30 AM
I had some track that only took T-bolts, but I had to file the heads to make the bolts a little narrower. Now I purchase Kreg track. I think it is better and more versatile.
BJ
View DrDirt's profile
DrDirt
4426 posts in 3828 days
#6 posted 02-09-2014 12:37 AM
you can get inexpensive t-track from McMaster carr.
http://www.mcmaster.com/#t-tracks/=qlzs4p
their track is for 1/4-20 bolts, but is about 3dollars/foot.
View Loren's profile
10477 posts in 3733 days
#7 posted 02-09-2014 12:52 AM
It’s all pretty similar in my experience… I think the stuff that
takes the 7/16” nuts is actually “mini” t-track. What you
should not expect to be able to do is lay tracks from
different suppliers in the same grooves at the same depths.
Generally the stuff won’t take a carriage bolt (which has a
nice square section to prevent twisting adjacent to the head)
unless you grind flats on two sides and take some material
off the top. The brass thumb screws I got for 1/4-20
threads don’t thread onto toilet bolts, though standard
1/4-20 nuts do.
HarveyDunn
#8 posted 02-09-2014 01:02 AM
OK, that’s a good point. What I’m most interested in is the ability to buy the gizmos from whomever has the most cleaver-seeming ones.
CharlesA
#9 posted 02-09-2014 01:09 AM
That’s why I’ve chosen the most versatile t-track—to not limit options.
View Fish22's profile
Fish22
83 posts in 3199 days
#10 posted 02-09-2014 01:10 AM
I prefer the Incra t track and t track plus.
-- Bryan, South River, NJ
TopamaxSurvivor
18341 posts in 3761 days
#11 posted 02-09-2014 01:20 AM
Loren, Did you try cleaning the brass t screws up with a 1/4-20 tap?
CharlesA, Which do you use that is the most versatile?
CharlesA
#12 posted 02-09-2014 02:12 AM
When I built my router table I just grabbed some t-track somewhere not realizing the difference. I bought a Freud type router fence and when I tried to install it discovered that it would punt accept the 1/4 inch bolts that were standard. There are workarounds, but it can be a pain in the short term. Since then I have replaced that t-track and installed new t-track sung only Kreg or incra that will accept about anything. That’s what I meant by versatile. I don’t use t-track in huge quantities, so I’m not looking to save a lot of money when I know these will work.
#13 posted 02-09-2014 02:17 AM
Topamax – no, and that’s a good idea as maybe the peaks
in the threads are a little high. The toilet bolts also have that
gold color coating and maybe it fools with the fit.
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1723 days
#14 posted 02-09-2014 02:47 AM
I think incra makes the best t track
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
TopamaxSurvivor
#15 posted 02-09-2014 06:23 AM
Thanks, I’ll keep Kreg and incra in mind. I haven’t made anything using it yet, but if it is a PIA, it is not a bargain at any price ;-)
