joining edges of an octagon?
« back to Joinery forum
Forum topic by mzimmers posted 02-07-2014 07:57 PM 2666 views 0 times favorited 9 replies Add to Favorites Watch
View mzimmers's profile
mzimmers
192 posts in 3823 days
02-07-2014 07:57 PM
Topic tags/keywords: octagon joining
Hi, all -
I did a search, and found some threads related to this, but nothing quite what I was looking for. I want to build an octagon from 2×6 boards. I want the boards up on edge (so the octagon, lying down, would be 5.5” high). It doesn’t need to be super strong, but I’d like to improve upon just gluing miter joints.
I can’t figure out a way to use my dowelling jig for this, and I don’t have a biscuit joiner. Any creative suggestions?
Thanks.
-- M. Zimmers
9 replies so far
View brtech's profile
brtech
1020 posts in 2831 days
#1 posted 02-07-2014 08:04 PM
How about pocket hole joints?
Not sure why your doweling jig wouldn’t work. As long as you orient it the right way, it should make the right holes. You could rig up a special purpose dowel jig just for this project pretty easily.
How big is each side? It it’s not too long, you could make a jig to hold the board to cut a spline on your table saw.
You could also build a simple jig to cut the spline groove with a router.
View bondogaposis's profile
bondogaposis
4611 posts in 2259 days
#2 posted 02-07-2014 08:06 PM
How long are these boards? You could spline them using a table saw if they are short enough to handle on that machine. Other wise you might have build a jig for a router to cut the grooves.
-- Bondo Gaposis
mzimmers
#3 posted 02-07-2014 08:09 PM
This is my dowelling jig:
Jessem Jig
There may be a way to do it, but I can’t come up with it.
Each side will be a little less than 2’. The spline idea is interesting; I could do that on my router table without a jig, I think.
-- M. Zimmers
View madts's profile
madts
1843 posts in 2248 days
#4 posted 02-07-2014 08:12 PM
Take your boards and cut through at a 45 deg. angle half way through each board on one end only. This will give you you want . I can not draw it for you right now. So a 45 deg. vee on each board and put it together.
-- Thor and Odin are still the greatest of Gods.
View DKV's profile
DKV
3940 posts in 2412 days
#5 posted 02-07-2014 08:56 PM
The answer is in your user guide.
-- This is a Troll Free zone.
mzimmers
#6 posted 02-07-2014 09:00 PM
Those boards aren’t cut at the right orientation for my project. The miter (bevel?) cuts will be perpendicular to those.
Just as an FYI for the readers, I’ve done the ones in the pic, and they work beautifully…IF you can consistently place each board in the jig, which isn’t as easy as it looks. I’m looking into ways to simplify that.
-- M. Zimmers
View mahdee's profile
mahdee
3844 posts in 1676 days
#7 posted 02-07-2014 09:07 PM
You may be able to run the bottom of each end on the saw to make a cut in the middle. Then use a 1/8” strips (maybe from a darker/lighter wood) to join them together and clamp. You can run it twice for a thicker strips.
-- earthartandfoods.com
mzimmers
#8 posted 02-07-2014 09:10 PM
brtech: somehow I missed your reply earlier. I was thinking of pocket holes, too. My only concern would be that, at the needed angles for an octagon, the screw are coming close to pulling on the grain, not against it. But…this still might be the easiest way to go.
-- M. Zimmers
View Jim Finn's profile
Jim Finn
2622 posts in 2830 days
#9 posted 02-07-2014 11:00 PM
How about , after gluing it up, drill holes through each joint and fill with a dowel and sand off flush.
