What Air Compressor for Jet Hydraulic Jack
« back to Hand Tools forum
Forum topic by Lentze posted 02-07-2014 01:47 AM 2467 views 0 times favorited 9 replies Add to Favorites Watch
View Lentze's profile
Lentze
14 posts in 1652 days
02-07-2014 01:47 AM
Topic tags/keywords: compressor press jack hydraulic air run
Hello,
I have the JET 20 ton hydraulic jack that I am using in a shop press to push metal dies into leather.
It calls for an air compressor running at 101-145 psi at 7.85 cfm. I am not too familiar with air compressors and I was wondering if anyone has some advice for a small/quieter unit capable of that kind of output?
Thanks!
9 replies so far
View bigblockyeti's profile
bigblockyeti
5120 posts in 1719 days
#1 posted 02-07-2014 02:02 AM
There is no compressor that anyone would consider “small” that would have that kind of output. Given the airflow requirement, you’re almost certainly looking at a 240V compressor.
Lentze
#2 posted 02-07-2014 02:06 AM
Oh man, I was hoping that wouldn’t be the case!
Well – do you know if there are air run jacks in the 12 – 20 ton range that can run on a lot less capacity?
bigblockyeti
#3 posted 02-07-2014 02:22 AM
The only air jack I’ve ever used was a 50 ton and it took a lot of air. Most of the 60 gallon air compressors that run on 240V, sold at the big box store can be had for $400 when on sale. I would think you could run the jack at lower air flow and the same pressure and just have it run slower. Might be worth trying another compressor to see how it might do before assuming anything.
Lentze
#4 posted 02-07-2014 02:33 AM
how slow do these things usually go? I got this unit to replace a 12 ton manual bottle jack because I thought it might be faster…! Maybe sticking to good old elbow grease would be better?
View REO's profile
REO
928 posts in 2073 days
#5 posted 02-07-2014 02:34 AM
the jack will work at lower cfm. that is a continuous load and you will be loading it intermittently. Place part, press, unload, remove or move part, do it again. in the mean time the compressor during off times the compressor will replenish the tank. I would think you could get along with a 20-30 gallon 110V compressor in the less than 400 dollar range fairly well. I don’t know what your cycle times are. If you want to get the cycle time up an arbor type press may work for you if properly set up. less elbow grease with the pneu unit but the 20 ton will be almost half as much lift per pump than the 12 ton.
Lentze
#6 posted 02-07-2014 02:39 AM
Yeah – I tried to run it on an old compressor I had laying around at 2.25 cfm open flow 84-114 psi. It didn’t seem to do anything. Though maybe the flow wasn’t fully open? It has some push lock on it that keeps the output at 1 bar. I am not too familiar with compressors though.
Lentze
#7 posted 02-07-2014 02:48 AM
Well, messed with that push lock and got it to work. Wish I would have figured that one out hours ago!
So now my question is – can these jacks get going pretty fast or will there not be much difference?
woodbutcherbynight
4555 posts in 2408 days
#8 posted 02-07-2014 02:52 AM
I use one at work, be careful we have had people crush things that were not meant to be crushed because it moves faster than hand cranking it.
Lentze
#9 posted 02-07-2014 10:46 PM
thanks will do. I could always hook up dual hand push valves to keep both hands out of the way…might be overkill though
