Side sanding on bench grinder
Forum topic by RippKutt posted 02-07-2014 01:14 AM 1040 views 0 times favorited 4 replies Add to Favorites Watch
View RippKutt's profile
RippKutt
13 posts in 2166 days
02-07-2014 01:14 AM
Topic tags/keywords: safety side wheel grinding drill-driver question sharpening
Hello Jocks. Here is my deal. I bought this General Tool Grinding Attachment to sharpen my drill bits. $20.00 delivered. I have experimented with it on a few bits by side grinding on my bench grinder. It works super great, just take your time. Face grinding edge will give me a hollow grind. Yes I know, no side grinding. This is my thought. Why can’t I make a 6” grinding wheel out of plywood (I don’t trust MDF) and attach psa sandpaper to it and safely SIDE grind my bits on my bench grinder? My grinder is a dual wheel China Junk 6” at 3450 rpms. Maybe a solid oak or poplar wheel? I am also thinking of making a similar setup for my lathe and operating at a much lower speed. Hope to hear from someone. Thanx, Ripp
View cutmantom's profile
cutmantom
405 posts in 3028 days
#1 posted 02-07-2014 01:38 AM
I would worry about getting it balanced, lahe sounds better , lower speed will lessen over heating
View jap's profile
jap
1251 posts in 2047 days
#2 posted 02-07-2014 03:43 AM
Your idea should work,
-- Joel
View Woodknack's profile
Woodknack
11600 posts in 2373 days
#3 posted 02-07-2014 07:15 AM
I don’t know about running a wood wheel at 3450 for any length of time regardless of wood type but if you do make one for your lathe use MDF and double it up.
View waho6o9's profile
waho6o9
8187 posts in 2570 days
#4 posted 02-07-2014 01:20 PM
http://www.wkfinetools.com/contrib/hendersonM/sharpDisk/sharpDisk-7.asp
P. Michael Henderson has a great tutorial on making a disc for
a lathe on the links above.
