How do I finish dark walnut / birch....hope chest
Forum topic by Hartworks posted 02-06-2014 06:07 PM 1356 views 0 times favorited 3 replies Add to Favorites Watch
View Hartworks's profile
Hartworks
53 posts in 1504 days
02-06-2014 06:07 PM
Topic tags/keywords: question walnut finishing
I am constructing a hope chest with the framework / lid made of dark walnut and the panel inserts (front side and back) made of birch. I have read about a million different ways to finish but would like to hear from someone who has successfully finished walnut. I want it to appear natural and expose the grains and figures, so I guess I am saying as clear as possible. But I don’t really like the contrast with the light sapwood. I tried some dark danish oil and that just looked too dark. I tried some BLO, which looked nice but the sapwood was still too light. I tossed two coats of shellac over the BLO and really did not like the appearance it gave the piece. (mind you these are test pieces)
What I would like is a nice even tone, as close to natural as possible. I have also read that walnut will fade over time and lose its dark characteristic.
I have not tested the birch yet but think I can just go with BLO, wash coat shellac and top coat with GF High Performance Satin.
Some direction would be greatly appreciated.
-- Gary, California
3 replies so far
View VCF's profile
VCF
66 posts in 1478 days
#1 posted 02-06-2014 07:55 PM
Here is a walnut I finished just last year. I used a few coats of tung oil and finished that off wipe on polly.
-- Vieth Custom Furniture, https://sites.google.com/site/viethcustomfurniture/
View RogerM's profile
RogerM
790 posts in 2305 days
#2 posted 02-07-2014 05:41 PM
Gary – You can check out some of my projects which I generally finish this way:
- Sand to 180 – 220 grit sandpaper
- rag on Minwax golden oak stain (Lowes or Home Depot carries this) and allow to dry overnight.
- rub down with a clean cloth to remove dust and rag on a coat of Seal Coat diluted with an equal part of alcohol.
- allow sealer coat to dry several hours and rub out with 00 steel wool.
- Remove dust and debris with air and/or a rag containing mineral spirits
- Apply at least three coats of polyurethane diluted with an equal part of mineral spirits. I usually apply this with a lint free cloth (old T shirt works fine) and use semi gloss Minwax Polyurethane allowing at least 2 hours between coats. The more coats you put on the thicker and glossier it gets.
- Rub out with 800-1000 grit sandpaper or 0000 steel wool and remove debris as before.
- apply a coat of Black Bison Wax with 0000 steel wool and buff with a cotton cloth.
I hope this helps. Contact me if you have questions.
-- Roger M, Aiken, SC
Hartworks
#3 posted 02-08-2014 02:09 AM
Thanks Roger and VCF…I do believe I will try both methods and see what looks like what Im going for…thanks for takin the time
-- Gary, California
