Air spray varnish
Forum topic by Jerlac posted 02-06-2014 01:55 AM 784 views 0 times favorited 3 replies Add to Favorites Watch
View Jerlac's profile
Jerlac
112 posts in 1732 days
02-06-2014 01:55 AM
I got an hvlp gun and i would like t know at what pressure your shooting 20psi? And if there is some other advice you guys could give me would be amazing thanks
3 replies so far
View tefinn's profile
tefinn
1222 posts in 2462 days
#1 posted 02-06-2014 02:02 AM
Not really sure what your trying to ask. At 20psi your pressure is 20psi. You need to set the pressure at the compressor to 20psi and you’ll have that at any tool you’re using.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
4999 posts in 2518 days
#2 posted 02-06-2014 12:21 PM
I’m also not sure of the question, and the guns are different, and various finishes do take some tweaking. I also never spray varnish, it is so slow to dry the overspray coats everything in the area making a real mess. Other finishes can dry while airborne and just settle as dust. That said, for my conversion gun I usually have the compressor set at 45#, but then the regulator in the gun is set to 15# when the trigger is pulled. But like I said, I’ve never sprayed varnish.
View Tennessee's profile
Tennessee
2873 posts in 2539 days
#3 posted 02-06-2014 12:55 PM
Tom:
For those of us who spray from time to time, I put a splitter on my air compressor. One side provides full pressure, and the other side provides 35psi air, which is where I run my HVLP guns. I keep the water separator before the split. I also popped for two wind-up reels on the wall, one for the guns, one for general use. The gun hose is a much lighter hose, since I do most of my spraying in warmer weather outside and hose gets heavy.
