What is the "Tap Tone Test"?
Forum topic by Dallas posted 02-05-2014 11:28 PM 856 views 0 times favorited 3 replies Add to Favorites Watch
View Dallas's profile
Dallas
3599 posts in 2356 days
02-05-2014 11:28 PM
I have a bunch of Walnut and Maple and Cherry and Osage Orange.
How do I figure out the sound of a piece to make an electric guitar from or maybe even a semi-hollow body guitar?
3 replies so far
View Loren's profile
9752 posts in 3517 days
#1 posted 02-05-2014 11:33 PM
You mount or hold the board at the node points. Then you
can hit it with a rubber ball mounted on the end of a dowel
and get a clear tone.
The node points are around 1/6 in from the end relative to the
overall length. There’s a way to figure it out mathematically,
but for assessing thin soundboards the board is held pinched
between thumb and forefinger at the node area and tapped
with a finger in the center to assess the tap tone. Actually
we tap it all over. Fingerboards can be tapped the same way
and some electric builders believe it makes a difference. For
acoustic guitars I do not believe the fingerboard wood affects
the tone in a discernible way.
View Texcaster's profile
Texcaster
1266 posts in 1543 days
#2 posted 02-05-2014 11:59 PM
What Loren said. I tap with the fleshy end of my middle finger. Adjust your grip on the node up or down and tap, you’ll know when you find it. Some tap like a bell, others like a low gong, how long does it sustain? Both will work. Once I started luthiery, I automatically started tapping everything.
I’m more used to bass players that can hear the difference in a Rosewood, Ebony or Maple fingerboard. At gig volume it becomes academic.
-- Mama calls me Texcaster but my real name is Mr. Earl.
Dallas
#3 posted 02-06-2014 02:12 PM
Thanks gentlemen.
I will attempt to learn this skill as I try to learn the skill and art of Luthiery.
Eventually I would like to build a decent arch top or even steel string accoustic and the more I learn now the easier it will be later.
