How to make a juice groove
Forum topic by Don posted 02-05-2014 02:39 PM 4134 views 0 times favorited 17 replies Add to Favorites Watch
View Don's profile
Don
551 posts in 3243 days
02-05-2014 02:39 PM
Topic tags/keywords: question router
Ok, might be a simple answer to this but…..
I’ve made lots of cutting boards but this is the first time someone has asked for a juice groove in one so I’m looking for a little guidance so I don’t screw it up.
Is the easiest method to create a template 1/8” smaller than the groove and use a router & guide? Any tips or hints?
Cheers…Don
-- -- Don in Ottawa, http://www.donebydon.ca
17 replies so far
View jap's profile
jap
1251 posts in 2055 days
#1 posted 02-05-2014 02:57 PM
CNC router would probably be easy, though I doubt you have one or could afford one. So a template make sense.
-- Joel
View Don's profile
Don
#2 posted 02-05-2014 03:02 PM
CNC router is a nice to have.
Have one? No.
Afford one? Yes.
Space for one? No.
View larson1170's profile
larson1170
32 posts in 1612 days
#3 posted 02-05-2014 03:34 PM
I have seen some plans on here for making a sled for your router so you can use it to plane down cutting boards. Maybe you could adapt one of those plans to work?
View madts's profile
madts
1862 posts in 2340 days
#4 posted 02-05-2014 04:10 PM
You could make a panto-graph for the router.. That might be a way to go.
-- Thor and Odin are still the greatest of Gods.
View waho6o9's profile
waho6o9
8191 posts in 2578 days
#5 posted 02-05-2014 04:18 PM
This way works for me:
and the results:
117095 posts in 3578 days
#6 posted 02-05-2014 04:24 PM
Yes you have it right with the pattern Idea. Make sure your pattern is smooth with no defects,if you have defect a little bondo with fill big chunks back in. Double sided tape is great for holding the pattern in place. For a smooth groove use a sharp & clean router bit and take light cuts to prevent burning.
View pintodeluxe's profile
pintodeluxe
5664 posts in 2814 days
#7 posted 02-05-2014 06:01 PM
I would either use a pattern carpet taped to the board (especially if the groove is to be curved), or you might be able to setup the router table with stop blocks for consistent cuts.
Once you figure out the juice groove, start working on a carrot catcher accessory. Those carrots seem to fly everywhere when I chop them!
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1728 days
#8 posted 02-05-2014 06:30 PM
Make a thicker frame around your cutting board. (Easy enough to just nail on four pcs)
View degoose's profile
degoose
7233 posts in 3355 days
#9 posted 02-05-2014 07:33 PM
First choice CNC… failing that Kevins solution works a treat… can’t over shoot the corners…
View Don's profile
Don
#10 posted 02-05-2014 07:42 PM
Good ideas, thanks. The cutting board he wants made has one square end and one rounded end to it so I’m guessing Jim’s template idea is the way to go?
View Greg's profile
Greg
330 posts in 2874 days
#11 posted 02-05-2014 07:50 PM
Yup, and my advice would be to do it in multiple passes. This will make it easier to keep control of the router especially when rounding corners on the template. Make your final pass the shallowest (1/32”)-ish, and try not to pause. This will reduce the burning, and therefore the amount of sanding you will have to do. You only get one shot at this!l
-- You don't have a custom made heirloom fly fishing Net? http://www.Sierra-Nets.com
View Don's profile
Don
#12 posted 02-05-2014 07:52 PM
This is a 21×27 x 2” board so I don’t want to screw this up!
View oldnovice's profile
oldnovice
6855 posts in 3369 days
#13 posted 02-05-2014 09:18 PM
I ditto all those that said template! Just be sure to stay on the template, inside, outside, or to be sure, inside and outside as that “traps” the path of the router so you can’t drift away in either direction.
I assume that the juice groove will be near the edge so the outside template will need some way to raise it up to the CB surface and spacers to locate the CB within the template.
It’s a little more work but the other template can be held to the CB with double side tape.
Do a “bit less” groove first to make sure there are no template hang up!
View joeyinsouthaustin's profile
joeyinsouthaustin
1294 posts in 2073 days
#14 posted 02-06-2014 12:08 AM
I do this with something very similar to these suggestions. I use a collar and bit. I sized it a tad larger so I can run the inside, and outside diameter separatly. This allows more control and with the depth set right you can chose oval or round. It also comes out looking less, how do I say, like the others. (until now :) I put cleats to hold to board, and use “corner blocks”. I route to the blocks, then move them one at a time to keep the inner pattern from moving.(clamping helps too at this point) You will notice I made custom rounded corner inserts by drilling a whole in Ply with a forstner and cutting in in corners to get a nice rounded corner. Here is what these jigs look like in something other than digital ;) (props to waho69 for staying analog :)
Bottom with cleats.
Top with corner blocks.
The cleats can be moved… but the downside to this jig, is you need to make one for each of your board sizes.
-- Who is John Galt?
View Tony1212's profile
Tony1212
190 posts in 1735 days
#15 posted 02-07-2014 05:51 PM
I just got my weekly etip from Woodsmith magazine yesterday afternoon. They have a video on making juice grooves in cutting boards.
I think anyone can see the video.
http://www.woodsmithtips.com/2014/02/06/router-trick-for-grooves/?autostart=true&utm_source=WoodsmithTips&utm_medium=email&utm_campaign=7864
If you have problems seeing the video, let me know.
-- Tony, SW Chicago Suburbs
