Beginner question about how to stabilize a table
« back to Joinery forum
Forum topic by dnewell posted 02-05-2014 03:28 AM 6836 views 0 times favorited 8 replies Add to Favorites Watch
View dnewell's profile
dnewell
4 posts in 3088 days
02-05-2014 03:28 AM
Topic tags/keywords: table joint bracket
Hi everybody, I’ve got a simple question about table-building, specifically to do with joining the legs and the apron. I used a Rockler apron bracket (pictured) to join the apron pieces to the legs. Once I got everything screwed in it there was some wiggle in it. I can move the legs in most any direction I want. The movement isn’t major but over time it will become a problem. Would L-brackets be the solution here? A straight bracket recessed into the top of the legs and aprons?
8 replies so far
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1721 days
#1 posted 02-05-2014 03:37 AM
It looks like the corner of the leg is hitting the metal bracket. If so, this is stopping the leg from pulling tight into the skirt pcs.
You would need to move the metal bracket a little farther away from the edges of the skirt.
(Note:) This would change the distance you skirts are set in.
Or you could just bevel a little off of the corner of the leg. (easiest fix)
This will let the 2 bolts, in the middle of the bracket, pull the leg in tighter.
View crank49's profile
crank49
4030 posts in 2964 days
#2 posted 02-05-2014 04:13 AM
This is the place where a couple of tenons would make a tight joint.
Then you could trash that little piece of tin.
View wseand's profile
wseand
2796 posts in 3035 days
#3 posted 02-05-2014 04:17 AM
+1 on Kevin’s suggestion. Future tables, M&T works great.
dnewell
#4 posted 02-05-2014 04:24 AM
Thanks, Kevin, that’s helpful. I’ll give your suggestion a try.
I’d love to do an M&T sometime, but I’m only working with a table saw and miter saw for this project. Hence, the “beginner” question. Hopefully next time!
wseand
#5 posted 02-05-2014 05:07 AM
All you need is a table saw for M&Ton Table legs. It’s what I use on table legs, well a chisel too. Just FYI…
117085 posts in 3570 days
#6 posted 02-05-2014 05:21 AM
Most of the corner brackets on older furniture have an anchor bolt in the middle holes with nuts that can be tightened to take up any wiggle in the legs. Perhaps if you replace the center screws with anchor bolts and nuts it will help your problem.
View HerbC's profile
HerbC
1754 posts in 2852 days
#7 posted 02-05-2014 05:45 AM
+1 on trimming inside corner of leg to get clearance so the leg can be pulled tight.
+1 on changing out the screws to anchor bolts.
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View Woodknack's profile
Woodknack
11600 posts in 2373 days
#8 posted 02-05-2014 05:48 AM
The table leg is usually chamfered beneath the metal bracket, I’ve never used them though.
