water based polyacrylic finish on pens
« back to Woodturning forum
Forum topic by Sawdust2012 posted 02-05-2014 12:52 AM 1031 views 0 times favorited 2 replies Add to Favorites Watch
View Sawdust2012's profile
114 posts in 1646 days
02-05-2014 12:52 AM
Can water based polyacrylic be used as a clear finish on pens? I need a clear gloss finish, but CA glue makes breathing a challenge at best for about 3 days.
2 replies so far
4156 posts in 2343 days
#1 posted 02-05-2014 02:13 AM
Try Shellwax Cream maybe at Penn State Industries, very little odor compared to CA and much easier to clean up. With a pen you want a finish that dries quickly but hard. I apply my finish and then carefully push the blanks onto a coat hanger and hang them for at least a day before assembly. Gives the finish a time to truly cure completely and not have fingerprint marks show up later or a duller finish.
Never tried using poly on anything on the lathe and I am not much for water based finishes.
Just my experience, good luck.
View Wildwood's profile
2268 posts in 2068 days
#2 posted 02-05-2014 10:30 AM
Yes, a can of any water base polyurethane, polyacrylic, or lacquer will work. Finishing procedure takes longer but just as glossy and durable as CA finish.
Low odor & rattle can clear finishes faster than oil/waterborne brush/wipe on products need to read can label for warnings & precautions, and mask up unless working outdoors.
-- Bill
