Key hole hanger tool
Forum topic by daves1 posted 02-04-2014 03:34 PM 3399 views 0 times favorited 9 replies Add to Favorites Watch
View daves1's profile
daves1
188 posts in 2763 days
02-04-2014 03:34 PM
Topic tags/keywords: hangers holes question
Does anyone know of a tool that will make the key hole shape for hanging pictures wood projects. Or does anyone have any ideas on how to make these holes?
Dave
9 replies so far
View jmartel's profile
jmartel
7891 posts in 2147 days
#1 posted 02-04-2014 03:54 PM
http://www.rockler.com/hanging-slot-router-bits-router-bits
View HerbC's profile
HerbC
1755 posts in 2857 days
#2 posted 02-04-2014 03:58 PM
What you want to do can be done with a router and a keyhole bit. MLCS has one here.
I understand that it works better if you first use a standard 1/4” straight bit to rough in the slot, to the depth of the finished hole, then use the slot cutter to bore the larger hole and make the slot cut. You have to remember to return the bit to the large hole opening before raising it…
Good Luck!
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View oldnovice's profile
oldnovice
6849 posts in 3365 days
#3 posted 02-04-2014 06:02 PM
I have the one like below from Eagle America.
View Jim Finn's profile
Jim Finn
2656 posts in 2919 days
#4 posted 02-05-2014 01:36 AM
I have one I use that is like the one Oldnovice mentions. I use it to hang plaques that I make. I set it over the running router in the table and move it as far as I want to the left and then lift it out there. I do it in all one step giving me a slot with larger round holes at each end of the slot. I put it horizontal in the plaque or intarsia so that the user can adjust the item left or right to balance it to hang level.
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View hairy's profile
hairy
2703 posts in 3530 days
#5 posted 02-05-2014 01:53 AM
Here’s another option.
http://lumberjocks.com/projects/94693
I think I got them at Lowe’s.
-- My reality check bounced...
View Whiskers's profile
Whiskers
389 posts in 2024 days
#6 posted 02-05-2014 02:39 AM
I bought a keyhole bit from someone back when I was ordering stuff anyway but haven’t used it yet. I did need to put some keyhole hangers on some speakers that I wanted to mount fairly flush on a wall and found that Rockler carries metal keyhole brackets in their ever present hardware outlet section for $1 a pair. That may be a better solution depending on your project.
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1620 days
#7 posted 02-05-2014 02:51 AM
I’ve been doing it in the back of my lamps by hand with a Dremel flex shaft. I start with a 3/8” drill or a carbide cutter to make the hole for the screw head, use a smaller cutter (1/8”) for the smaller slot, then undercut the smaller slot with a 3/8” wheel cutter. The keyhole cutter in a router sounds nicer but it wouldn’t work for me with only the tiniest flat surface to work from.
-- Malcolm Laurel - http://MalcolmLaurel.com
daves1
#8 posted 02-05-2014 02:56 AM
Thanks everyone for links and ideas. I know what I need to do. Gotta love this LJ website.
oldnovice
#9 posted 02-05-2014 03:35 AM
daves1, you and me and a bunch of others!
