delta 14" swivel head lathe in Minneapolis 450.00
« back to Woodturning forum
Forum topic by REO posted 02-04-2014 12:50 PM 981 views 0 times favorited 4 replies Add to Favorites Watch
View REO's profile
REO
928 posts in 2071 days
02-04-2014 12:50 PM
Topic tags/keywords: resource tip
View Wildwood's profile
Wildwood
2305 posts in 2132 days
#1 posted 02-04-2014 11:04 PM
Lathe discontinued by Delta, best advice for people buying this lathe new was check store’s return policy before buying.
Guess needed a little luck with this lathe, some people got a year or two of use out of them before problems arose.
Not so lucky people had these problems right away vibration, vertical headstock/tailstock misalignment of over 1/16”, a rattling headstock, tailstock that could not be adjusted to lock down securely, problems in the indexing mechanism.
I would recommend people stay away from this lathe, not sure spare parts available or affordable if find them.
-- Bill
View REO's profile
REO
#2 posted 02-05-2014 09:45 PM
Not mine I just posted what I found. I do know that there are people that are quite well satisfied with this machine. Most of the problems you have listed have been dealt with satisfactorily in other threads.
Wildwood
#3 posted 02-05-2014 10:13 PM
REO, someone with your experience with woodworking machines might be able to make that lathe work including modifying it to run right.
Delta did not stand behind that lathe very long before dropping it.
My own experience with Delta Asian reeves drive lathe (46-700) 12”x36” required modification to work. Removed the reeves drive, added a pulley to spindle mounting motor a bracket attached to lathe bed which allowed the motor to swing. You swung motor in and moved the belt along pulleys to change speeds. Friend & I took it to local machine shop to make the required parts way back then only cost $170 for parts & labor.
That lathe not sits on floor in back of my shop collecting dust & rust.
-- Bill
View Arlin Eastman's profile
Arlin Eastman
4216 posts in 2559 days
#4 posted 02-14-2014 10:45 PM
Roger
Thank you for the Tip on buying this lathe, however, I was still hoping you are making my lathe like you said. :)
Arlin
-- It is always the right time, to do the right thing.
