10 year kiln dried cherry.
Forum topic by Broglea posted 02-03-2014 02:38 AM 1013 views 0 times favorited 5 replies Add to Favorites Watch
View Broglea's profile
Broglea
685 posts in 3120 days
02-03-2014 02:38 AM
I have an opportunity to buy 400 board feet of 4/4 cherry. The seller told me the cherry was kiln dried to 7% moisture content initially, but since has been stored in a non humidity controlled environment for the last 10 years.
What would the moisture content in the lumber be now? My guess would be greater than 7%, but would it still be stable enough to use in furniture that will be indoors?
5 replies so far
View pintodeluxe's profile
pintodeluxe
5706 posts in 2842 days
#1 posted 02-03-2014 02:54 AM
It will probably be between 7-10% MC. Cherry is pretty easy to dry out again. You can run some box fans and a dehumidifier in your shop and it will dry out in a week or two.
View WDHLT15's profile
WDHLT15
1748 posts in 2505 days
#2 posted 02-03-2014 05:07 AM
12% is generally what lumber will equalibrate to over an extended period of time unless your climate is very dry with low humidity.
View LakeLover's profile
LakeLover
283 posts in 1968 days
#3 posted 02-03-2014 12:27 PM
Buy a moisture meter. It will eliminate the guess work.
View Nomad62's profile
Nomad62
726 posts in 2987 days
#4 posted 02-03-2014 08:08 PM
It all depends upon the area in which the wood was stored vs the area it will be kept. Most areas will maintain a 12-15% content, others more or less. I’m in NW Oregon, and my outdoors wood will dry to about 25%; my Brother is in Nevada, and it dries almost bone dry there. If you use it for yourself, I’d give it a month in your home before using it just to be on the safe side.
View DrDirt's profile
DrDirt
4424 posts in 3771 days
#5 posted 02-03-2014 08:25 PM
If you are in a high humidity but worse – true 4 season area with cold winters/hot summers – I would look at it for severe checking – after 10 years unconditioned freeze thaw, you may have a lot of scrap.
It will be plenty stable, just make sure you have enough usable length.
