Guide bushings on a Bosch trim router (PR20) - Bosch or P-C?
Forum topic by HarveyDunn posted 02-02-2014 04:28 PM 1130 views 0 times favorited 3 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1933 days
02-02-2014 04:28 PM
Just acquired a Bosh trim router PR20. No accessories except for the fixed base and the edge guide.
I want to do some template routing. Do I want to buy the Bosch-specific bushings (I believe they call them “template guides” or do I want to work out a way to use the Porter-Cable bushings instead? I plan to get the plunge router base eventually.
3 replies so far
View Fuzzy's profile
Fuzzy
298 posts in 4190 days
#1 posted 02-02-2014 04:30 PM
Make or buy a baseplate that accepts the standard bushings.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
HarveyDunn
#2 posted 02-02-2014 04:34 PM
Fuzzy, by “standard bushings”, do you mean the P-C bushings? Or do you mean those design by Bosch for this router?
Fuzzy
#3 posted 02-02-2014 04:58 PM
I was referring to the P-C as “standard” ... but, you can make a baseplate that will accept whatever bushings you might already have i n order to save some $$$. I have several sets of the P-C style that I’ve picked up over the years, and I make every baseplate to accept those, unless I need something special where bushings are not an issue.
