Finding the Center Point
Forum topic by codysmith posted 333 days ago 697 views 1 time favorited 20 replies Add to Favorites Watch
View codysmith's profile
codysmith
8 posts in 355 days
333 days ago
I was wondering what techniques LJ’s are using to find the center point of the end of a board accurately. I am trying to mark the dead center on the end of some 1×4’s to make some tenons in a Leigh FMT jig. Sometimes I measure and mark it right on the money and other times I am off just enough to be frustrating.
I’ve noticed that some of the boards vary from the standard 3/4” x 3-1/2” by as much as 1/8”. Is there a tool or technique I could use to find the center and speed up the process rather than wasting time cutting and then making adjustments?
View bob101's profile
bob101
46 posts in 348 days
333 days ago
You could start by planing the boards to be exactly the same which would be easier, But it sounds like you are using dimensioned stock from the store, if this is the case I would just use a good rule and measure twice, and hope for the best.
-- rob, ont,canada
View DaveH's profile
DaveH
372 posts in 676 days
333 days ago
You would think for $800 bucks the jig would find the center for you. Draw an X from corner to corner.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
View randal's profile
randal
54 posts in 337 days
333 days ago
Try this. Take a ruler and tilt it until you have an exact even amount of inches. Example, a 2×4 is approx 3.5” wide. Tilt the ruler until it “measures” 4 inches and the halfway point is 2”. Easier than all those 1/16ths and 1/32nds.
I also bought a center point tape measure several years ago. One side is the measurement, then find that measurement on the other side and that’s the middle. Works neat.
-- Randal, DeKalb, Illinois
View CessnaPilotBarry's profile
CessnaPilotBarry
1287 posts in 600 days
333 days ago
I use a combo square.
- Set it approximately half width by eyeball
- Use it to make a pencil mark
- Flip the square, and do the same from the other side
The center is exactly between the two marks. It doesn’t matter if the square was set more or less than the 1/2 way point. It’s very easy to see the center point between marks 1/8” apart, but not edges 3 1/2” apart.
Try it and see!
-- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread...
randal
333 days ago
Try this link to see the center point tape measure.
http://www.rockler.com/product.cfm?Offerings_ID=1256&TabSelect=Details
View juniorjock's profile
juniorjock
790 posts in 663 days
333 days ago
There’s lots of ways to do it. But I do agree with DaveH. That is if it’s practical for your application.
-JJ
-- JJ...... I guess you could say I'm a 54 year old "juniorjock". — Make things with wood.
codysmith
8 posts in 355 days
332 days ago
Thanks for all of your suggestions. I really appreciate and will try all of them, especially the center point tape measure.
View mgradwohl's profile
mgradwohl
190 posts in 711 days
332 days ago
+1 on Randal’s idea of just skewing a nice ruler. That’s the way the old guys did it. Need to mark a 7 inch board into thirds? Well, skew the ruler until it spans from 0 to 9, then mark at 3 and 6. Your board is now in thirds. Need to mark it in half? Skew the ruler until you’re at 8, and mark at 4. You can do this for any number of sections.
codysmith
8 posts in 355 days
331 days ago
I totally agree with the ruler skewing method. I can’t believe I never thought of that before. Thanks Randal.
View OttawaP's profile
OttawaP
53 posts in 624 days
324 days ago
The thing about the FMT is that it does not need to be “perfect” centered as long as you reference the tenon and mortice on the correct side when you place them in the jig your joint alignment will be 100% perfect.
The FMT is an exceptional tool to use. I just used it to install 4 corner dowels into a big old newel post. I made a matching template so I could drill out the stair tread and the post and dowels just slid in nicely.
-- Paul
View ryno101's profile
ryno101
248 posts in 562 days
304 days ago
My technique, for what it’s worth (I do a fair amount of turning…) is to use a “center finding rule” to find the center point of all faces, connect the lines, then use the “corner to corner” method to connect the opposing corners… what results is a box, the center of that box is the true center of the piece.
-- Ryno
7670 posts in 1116 days
304 days ago
Here is a thought…. simple to make and foolproof.
View Kindlingmaker's profile
Kindlingmaker
1476 posts in 424 days
304 days ago
CharlieM1958 is right on target but use a 5mm mechcanical pencil so as the lead line is always the same width.
14932 posts in 749 days
304 days ago
I use a jig similar to Charlie but more often then not I use an adjustable square as CessnaPilotBarry does.
View Rob 's profile
Rob
197 posts in 565 days
304 days ago
I’ve made that dowel jig a few times but I’ve never gotten it to be that accurate. I tried again tonight and found it off by 3/64ths. But I suppose you could run it both ways giving you two lines to gauge the middle by, much like using the combo square. I’ve tried to make a jig that works on the principle of the Starrett’s centre finder but couldn’t get it dialed in. I wanted it for finding the centre of circles which I find very difficult. I’ll have to try again sometime unless I just break down and buy one. Anyone have the Starrett? And if so, how is it?
View jm540's profile
jm540
133 posts in 317 days
303 days ago
i just divide mark from both ends and split the difference. I have used the tilt method it works but I cant convince my self to trust it. I also use a slide square
-- jay Rambling on and on again
View jeffthewoodwacker's profile
jeffthewoodwacker
487 posts in 702 days
303 days ago
One issue to consider is that even dimensional lumber from the big box stores don’t run true the length of the board. I normally square up all stock before finding dead center and then check the length of the board for accuracy.
-- Those that say it can't be done should not interrupt those who are doing it.
View noknot's profile
noknot
218 posts in 339 days
300 days ago
It is important to start out with equal size stock or it will turn into a lot of small probs later, but the center finding rule not tape is what cha need . have fun
-- projects dont pay,pieces are profitable,production is painfull
View CaptnA's profile
CaptnA
114 posts in 711 days
300 days ago
Charlie has a version of what I have. Mine was copied from a commercial version. Its not pretty but it sure is functional. Mine uses a fine metal point instead of a pencil. Once marked I can highlight with a pencil. Pencils work for marking as long as they are sharpened consistently.
But I love making and using my own tools whe nI can.
-- CaptnA - "When someone hurts you, write it in the sand so the winds of forgiveness will scatter the memory... "
View motthunter's profile
motthunter
2079 posts in 697 days
300 days ago
I use a center finding guide that I made. It is a rather basic jig
-- making sawdust....
