Fence Systems
Forum topic by Rif posted 02-02-2014 12:48 PM 738 views 0 times favorited 2 replies Add to Favorites Watch
View Rif's profile
Rif
1 post in 1484 days
02-02-2014 12:48 PM
I have a Delta Unisaw with the 52” Unifence System, but I would like to upgrade to a Biesmeyer system. Will most Biesmeyer systems fit an older model Unisaw? Mine is a 36-953.
2 replies so far
View ScrubPlane's profile
ScrubPlane
190 posts in 2103 days
#1 posted 02-02-2014 01:55 PM
You may (likely) need to replace the ‘rails’ as well. Good luck…
View wbrisett's profile
wbrisett
203 posts in 2256 days
#2 posted 02-02-2014 02:01 PM
Rif, I don’t know why they wouldn’t. When I bought my unisaw 10 years ago they actually offered it in both a unifence and Biesmeyer fence options. I went with the Biesmeyer system, which I replaced two years ago with the Incra fence. I prefer the Incra for the repeatability. There are some downsides to the Incra. Unless you have tons of space in your shop, getting the 52” out of the Incra requires you to have two stops and you have to adjust the positioner for each one. However, since 90% of my cuts are less than 30”, I don’t have to change it over nearly as often as you would think.
Anyhow, might be worth your while to look at the Incra system. I know that when I got mine it was less than what a replacement Biesmeyer fence would have cost me. I was also able to sell my original fence on craigslist, which brought my cost down even more.
But, I do agree with ScrubPlane, I think the two systems offered on the Delta saw when I bought mine used different rails.
