skilsaw for cutting down panels?
Forum topic by daddywoofdawg posted 02-02-2014 12:43 PM 1250 views 0 times favorited 12 replies Add to Favorites Watch
View daddywoofdawg's profile
daddywoofdawg
1028 posts in 1569 days
02-02-2014 12:43 PM
I use a 7 1/4” skilsaw to cut the panels down to size.My question is would I be better to get a smaller 5 3/8” or a 4.5”VersaCut Circular Saw? I only would use it for 3/4” and down sheets.
12 replies so far
View Skippy906's profile
Skippy906
121 posts in 1981 days
#1 posted 02-02-2014 01:37 PM
I use a festol ts-55 for cutting up my ply. Love it, well worth the money I spent for it. After I cut with that saw, it is down to finished size. Anyway, I do not see a reason you could not go to a smaller saw for cutting ply, just make sure it will have the power that you need, and the lighter weight will be a benefit too.
-- Making progress
View Gene Howe's profile
Gene Howe
10477 posts in 3423 days
#2 posted 02-02-2014 02:18 PM
I have a little Skil saw. Probably a 5” blade. Been so long since I’ve used it the blade size escapes me. It’s underpowered for 3/4”. My go to saw system for plywood is a Skil 77 and a shop made track saw. The weight is not negligible but it’s always resting on the work, so not a problem. I like the heft, except when picking it up off the floor!
The most important part of any system for cutting plywood is a good blade and tooth pattern to match the work. IMO, size is way down the list of important considerations.
View MJCD's profile
MJCD
541 posts in 2365 days
#3 posted 02-02-2014 02:41 PM
I use a 6” SawBoss (9amp, Porter-Cable) as my primary saw – it’s great for ripping and crosscutting plywood, and for quick cut-offs on dimensional lumber. The saw is light, powerful (enough) and provides a nice edge.
The whole 7 1/4” blade, 13-15 amp idea is steeped in Construction/Contractor history: a 45 degree miter on a 2×4 – very few need this capability, but companies continue to grind-out these tools. Buy something lighter, less expensive – but not CHEAP! Home Depot has become the ”$29 will buy you a tool’ company.
MJCD
-- Lead By Example; Make a Difference
View dhazelton's profile
dhazelton
2766 posts in 2291 days
#4 posted 02-02-2014 02:50 PM
Buy (or make) a speed square for cross cuts. Two clamps and a straight edge make for accurate rips. Now you have what you can do with a table saw and you’ll keep all your digits.
dhazelton
#5 posted 02-02-2014 06:13 PM
IGNORE my comment above – I thought I was posting to the guy who wanted to make his own table saw from an upside down skilsaw. Sorry….
View mtenterprises's profile
mtenterprises
933 posts in 2687 days
#6 posted 02-02-2014 07:00 PM
You have a tool that works. Is it that you just want to buy a new tool?
MIKE
-- See pictures on Flickr - http://www.flickr.com/photos/44216106@N07/ And visit my Facebook page - facebook.com/MTEnterprises
dhazelton
#7 posted 02-03-2014 01:02 AM
I had a 6 1/2 inch Skilsaw that I loved, but the bearings went and I tried to pull it apart myself and long story short I don’t think they make it anymore. I don’t know why you would need anything other than a 7 1/4 now. You can get every blade type under the sun and they will probably be the cheapest version of them.
daddywoofdawg
#8 posted 02-03-2014 07:27 AM
The saw I have is fine,It’s just heavy,So I have seen the smaller saws and thought this might be nice to tame ply sheets.I have a 7 1/4 and a compound for cutting dimensional lumber.I just like something lighter I.e to me more control.
dhazelton
#9 posted 02-03-2014 02:34 PM
Ridgid had a 6 1/2 inch corded for a while. Lots of blade options there as well.
View DrDirt's profile
DrDirt
4424 posts in 3736 days
#10 posted 02-03-2014 04:21 PM
I think there are a lot of good saws out there.
I don’t believe that you will get any “Better” results with a smaller saw. But you may find the smaller lighter saw more convenient to handle.
Generally the larger blade should track straighter.
View crank49's profile
crank49
4030 posts in 2965 days
#11 posted 02-03-2014 06:24 PM
I wanted a ~6” saw and a left hand blade.
Never understood why most sidewinders have the blade on the other side of the saw.
What I wound up having to buy was a Milwaukee battery powered saw.
I will say that it is very very nice, and I do enjoy being able to see the cut line and the light weight.
Just wish the thing was not so pricey.
Bought the saw as a refurb and the battery on sale, but it was still almost $200.
View CharlesA's profile
CharlesA
3319 posts in 1792 days
#12 posted 02-03-2014 07:14 PM
I found that a better blade (a Freud in my case) greatly improved my cuts on panels.
