Jet DC wiring question
Forum topic by Medickep posted 02-01-2014 06:21 AM 857 views 0 times favorited 10 replies Add to Favorites Watch
View Medickep's profile
Medickep
569 posts in 1610 days
02-01-2014 06:21 AM
Topic tags/keywords: resource
When I bought my used Jet DC 1100 the guy had it wired for 220. Since my friend can’t cover over for awhile to add a 220 circuit, I thought I would switch it to 115 so I can start figuring out my setup for the DC. I look in the manual and it appears to be simple to switch the machine from 115 to 220, but when I pop the plate for the start stop switch and saw the diagram on how to wire it for the desired volt it looks nothing like what’s in there.
They show for terminals in a row and mine look nothing like that. Can anyone shed any light on this?
Thank you!
-- Keith
10 replies so far
TopamaxSurvivor
18162 posts in 3548 days
#1 posted 02-01-2014 08:30 AM
Connections are in the motor cover, not the switch.
View jonah's profile
jonah
1517 posts in 3171 days
#2 posted 02-01-2014 12:56 PM
Concur. The switch appears to be voltage agnostic.
Medickep
#3 posted 02-01-2014 01:49 PM
Topamax survivor-
I thought that may be the case but I saw no other cover!!
Jonah-
Are you saying it is behind the switch?
-- Keith
View johnstoneb's profile
johnstoneb
2692 posts in 2045 days
#4 posted 02-01-2014 02:12 PM
The switch is mounted in the motor cover. you have the motor cover off. The wiring that needs changed is in behind the capacitors, not the easiest place to get at but can be done.
-- Bruce, Boise, ID
Medickep
#5 posted 02-01-2014 07:27 PM
Thanks john, I’ll take a look!
-- Keith
Medickep
#6 posted 02-01-2014 10:20 PM
I see some wires going into the motor behind the case that houses the on/off switch. Is the switch where those wires end inside at the motor??
I can’t believe there’s no YouTube video for this!
-- Keith
TopamaxSurvivor
#7 posted 02-02-2014 01:32 AM
I have never had a Jet DC open, but if that is the back of the switch in the picture and those are the capacitors, the wires with the 2 and 3 on them are probably your motor leads. The Capacitor wires will attach to the motor leads. Good luck!
Medickep
#8 posted 02-02-2014 01:47 AM
I’m sure what that means so I think I’m calling an electrician!
-- Keith
TopamaxSurvivor
#9 posted 02-02-2014 01:50 AM
Probably a good idea ;-)
View Grandpa's profile
Grandpa
3259 posts in 2547 days
#10 posted 02-02-2014 02:56 AM
Have the electrician install the 220V receptacle and problem solved. Cover the motor wiring up.
