Coffee Table Design
Forum topic by MaroonGoon posted 01-30-2014 05:02 PM 1380 views 1 time favorited 14 replies Add to Favorites Watch
View MaroonGoon's profile
MaroonGoon
281 posts in 2163 days
01-30-2014 05:02 PM
I’m posting some pics of the coffee table I’m designing. It’ll be from cherry and walnut with two drawers using curly cherry as the drawer fronts. Let me know what you guys think or if you have any advice or recommendations for the design.
Thanks for looking,
Maroon
-- "Only put off until tomorrow what you are willing to die having left undone." -- Pablo Picasso
14 replies so far
MaroonGoon
#1 posted 01-30-2014 05:04 PM
The dimensions seem to be hard to see. It is 24” wide, 42” long and 18” tall. The breadboard ends and walnut edges are 3” wide, the cherry boards (2 glued together x 2) are 8.25” wide and the center walnut strip is 1 1/2” wide.
View swoper's profile
swoper
59 posts in 3430 days
#2 posted 01-30-2014 05:18 PM
I like it, clean design and the cherry is my favorite. With winter keeping me out of my shop I am looking for spring time projects and I might copy your idea to a desk format.
-- Harry, Jackson Mi
View Handtooler's profile
Handtooler
1628 posts in 2337 days
#3 posted 01-30-2014 05:39 PM
Quite Nice! Are the legs tapered on two adjacent sides? Drawers seem to appear proportional to the table, maybe could be a tad more shallow depending what you intend to store.
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
MaroonGoon
#4 posted 01-30-2014 06:15 PM
swoper feel free to use it. Yes, Handtooler the legs are tapered on two sides.
Once I examined the design, it seemed to me the drawers might be a tad large or wide, even though the proportions fit. Maybe if I used three drawers instead of two, it can maintain the proportions while decreasing the size of each individual drawer.
Handtooler
#5 posted 01-30-2014 06:40 PM
You’re still in the design phase, so play around and decide what most appeals to you and your spouse.
View distrbd's profile
distrbd
2252 posts in 2651 days
#6 posted 01-30-2014 07:16 PM
What about the size of the tapered legs,are you planing on keeping them narrow and clean looking or chunky and thick?the picture bellow is a similar design but it’s made out of reclaimed wood:
-- Ken from Ontario, Canada
View BigRedKnothead's profile
BigRedKnothead
8542 posts in 2187 days
#7 posted 01-30-2014 10:20 PM
Looks pretty good. To my eye the legs could be a little thicker. But some of that’s just preference.
-- "At the end of the day, try and make it beautiful....because the world is full of ugly." Konrad Sauer
View MarkTheFiddler's profile
MarkTheFiddler
2068 posts in 2393 days
#8 posted 01-30-2014 10:39 PM
I like it a lot! Good clean lines. The other guys got me thinking about the legs as well. I might adjust the legs to be the same width as the separation between the drawers. It may me a grand total of 1/2 inch more thickness?
Regardless – it will be awesome!
-- Thanks for all the lessons!
TheWoodenOyster
1317 posts in 2140 days
#9 posted 01-30-2014 11:49 PM
Just make sure you have a plan for those breadboard ends. The difference in shrinkage and expansion of the different plank orientations will cause the breadboard ends to move at a different rate than the rest of the top. When I did my breadboard ends, I had no idea what I was doing. Luckily, I tongue and grooved the ends on and they have remained pretty stable. The top boards running longways shrink and expand about 2 mm from winter to summer. Let me know if you have no idea what I am talking about and I will explain further, as will others I bet
Other than that, I like it. It looks almost exactly like my very first woodworking project which was a maple coffee table. Useful and pleasing to the eye.
Good Luck!
-- The Wood Is Your Oyster
TheWoodenOyster
#10 posted 01-30-2014 11:52 PM
Holy Cow!!! I just saw your MaroonGoon name and figured you might be an aggie. Turns out we walked the same halls and probably sat in the same seats in class. We definitely ogled the same tools in the shop. I was class of 2010, graduated Construction Science.
GIG EM AGS!!!
View wseand's profile
wseand
2796 posts in 3247 days
#11 posted 01-31-2014 04:54 AM
I like it.
The only thing is the top seems a bit out of proportion. Maybe it needs to be a couple of inches longer. Maybe its just the measurement lines throwing me off.
View Lee Barker's profile
Lee Barker
2170 posts in 3055 days
#12 posted 01-31-2014 04:35 PM
Lots of helpful thoughts here.
If those are floating panels, keeping the grooves clean, and scooting things around, could be annoying. A glass top would be a workaround.
Or a flat top with breadboard ends.
If that were mine, I’d make the drawers wood on wood and pullable from either side. Flush mount ring pulls would be a nice touch.
Kindly,
MaroonGoon
#13 posted 01-31-2014 09:27 PM
Great advice guys, its truly appreciated! I’m glad there has been some thought put in on the legs, I could definitely see them thickening up a little bit..I was trying to match them to the end table I made but obviously.. a bigger table needs bigger legs!
Right now, the legs above are 1.5” wide, I might laminate two pieces together to make it 2”- 2.5” wide and taper it down to 1” at the bottom.
Oyster how funny! We probably did! Would you happen to have pictures of your breadboard ends process? This will be my first attempt at breadboard ends…
View dhazelton's profile
dhazelton
2798 posts in 2502 days
#14 posted 01-31-2014 10:05 PM
I think it looks pretty sexy as is. The thinner legs are delicate and make the body seem like it’s floating, kind of a Shaker esthetic. Make it be whatever YOU and your significant other wants. We don’t live in your house – don’t let us tell you what it should look like.
