BORK for a Unisaw
Forum topic by bbc557ci posted 01-30-2014 03:50 PM 1015 views 0 times favorited 3 replies Add to Favorites Watch
View bbc557ci's profile
bbc557ci
595 posts in 2038 days
01-30-2014 03:50 PM
Been reading the reviews here on LJs about the BORK riving knife, and came out with a question…
From looking at the various photos, it looks like the bracket blocks access to the arbor for blade changing. How do you BORK owners change blades?
My early/mid ‘90s Unisaw already has a bracket that looks like could set a splitter into. Anyone just take a piece of 1/8 in. steel and make up a splitter to fit in the existing Uni bracket? Seems like it would work ok…yes/no?
Thanks
-- Bill, central NY...no where near the "big apple"
3 replies so far
bbc557ci
#1 posted 01-31-2014 10:39 PM
TTT 23 hours and counting LOL
Aw c’mon there’s gotta be a few BORK users here, right? :o)
View knotscott's profile
knotscott
7980 posts in 3340 days
#2 posted 01-31-2014 11:34 PM
It doesn’t block access to the arbor….change the blade like you always have.
View BorkBob's profile
BorkBob
127 posts in 2657 days
#3 posted 02-22-2014 04:29 PM
I think Bill is talking about the other side of the blade, Scott. The BORK mounting arm mounts to the top and side of the arbor bracket. It takes up most of the space that is needed to use a second wrench for blade changes.
I ground down the wrench for my Grizzly 1023SL but remembered a trick from high school shop class. A scrap of wood that will bridge the throat opening works very well. Just jam and hold it against the front of the blade and loosen the nut. For tightening, the BORK splitter will drop down to allow you to put the scrap against the back of the blade. A bonus is that the the blade will “slip” before the nut gets too tight.
-- Please Pray for Our Troops / Semper Fi / Bob Ross / www.theborkstore.com
