blades for shop-made scraping planes
« back to Hand Tools forum
Forum topic by ballsofclay posted 01-30-2014 02:55 PM 1332 views 0 times favorited 8 replies Add to Favorites Watch
View ballsofclay's profile
ballsofclay
12 posts in 1546 days
01-30-2014 02:55 PM
I’d be curious to know if anyone has made a scraping plane and what you used for the blade. I have a few very thick (1/4 inch) blades for wooden planes. I am not sure about specifically what kind of steel, but it is definitely a high-carbon steel and judging by the way it sharpens I think it would be too hard/brittle to turn a hook like one would on a card scraper. Would it be suitable to make a scraping plane with a blade with no hook? I see Lie-Nielsen does not advise turning a hook on theirs, but other manufacturers do.
I currently have a Veritas large scraping plane and have always turned a hook on it, but it’s not very useful for me because it is too big and I find that the surface is at all slightly out of flat (really not a sin on the outsides of a cabinet in my opinion) then the plane chatters or does not make enough contact to get a good cut. I think what I really want is the smaller Lie-Nielsen scraping plane but I am trying to economize my woodworking costs and avoid pricey tool purchases.
8 replies so far
View Tim's profile
Tim
3784 posts in 1929 days
#1 posted 01-30-2014 07:26 PM
You could buy the Lee Valley or Lie Nielsen replacement blades if you wanted to. Otherwise saw blades make a good scraper. Depends on the level you’re going for I guess. Not sure about the hardness of the inside of circular saw blades, but that might be an option for steel thicker than a handsaw blade. Of course you can always buy tool steel from McMaster Carr and similar.
ballsofclay
#2 posted 01-31-2014 11:31 PM
Are the thicker planes for the Lie-Nieslen and similar scraping planes a softer steel than a standard plane iron?
I am asking about the blades I have because they are really nice blades but I am having trouble finding a project for them.
View Don W's profile
Don W
18686 posts in 2535 days
#3 posted 01-31-2014 11:42 PM
I’ve made scrapers with both vintage plane irons and scraper blades. The thinner blades work better with a hook. As the blade gets thicker, the hook seems less important.
ballsofclay
#4 posted 01-31-2014 11:45 PM
Do you feel one is better than another? What are the differences between the thick and thin blades in your experience?
Don W
#5 posted 01-31-2014 11:55 PM
For fine scraping on really difficult grain I like the hook especially in the larger scrapers. The smaller scrapers I made with block plane blades works well. I think the blades without a hook push harder. If I could only have one I’d want the hook. What I like about the non hook is they are quicker and easier to sharpen. I have a place for both in my shop.
You can hook the thicker irons if they are tampered correctly.
View hydro's profile
hydro
208 posts in 1719 days
#6 posted 02-01-2014 12:06 AM
Here are a couple of scraper planes I made for a bar rail moulding. The blades are pieces of an old cheap hand saw, shaped and with a hook pulled over. They worked very well to smooth out the project.
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
View Mark E.'s profile
Mark E.
387 posts in 3710 days
#7 posted 02-01-2014 01:14 AM
Not to get too far away from wooden planes, but, have you tried a Stanley No.80?
I have one of these with a Hock iron, ground to 45* with a hook. The nice thing about the 80 is you just set the iron flush to the bottom, then use the thumb screw to adjust the ‘depth of cut’.
-- Mark
hydro
#8 posted 02-01-2014 02:34 PM
Mark,
The scraper planes in my post are inspired by my Stanley #80.
