| Forum topic by HokieMojo | posted 330 days ago | 221 views | 0 times favorited | 7 replies | ![]() |
330 days ago |
Everyone’s been real helpful here, but I could use some more advice related to a mistake. I wanted to get some thoughts about the best way to fix my poor work. Can I still use titebond glue or have I essentially sealed the wood so that it will not penetrate? I work about trying to sand off the finish because the jointes will then fit way too loose. Maybe a quick scuff sanding followed by something like gorilla glue instead of titebond? I’m really desperate. Any help you guys can provide would be greatly appreciated. Ugg, I can’t believe I let this happen. I thought I wiped everything down well to avoid running of the finish, but it still happened and ran onto the sections to be glued. |
