How to join round leg to stretcher without squaring part of it
« back to Joinery forum
Forum topic by HarveyDunn posted 01-30-2014 02:33 PM 4234 views 0 times favorited 19 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1815 days
01-30-2014 02:33 PM
I’m taking a woodworking course, yesterday we learned how to joint round legs to stretchers by first squaring up a bit of the round leg then making a mortise in the squared-up part.
Just out of curiosity, I’m wondering if there are techniques for jointing flat boards to round legs without first squaring up the round part. Can a biscuit joiner do that? Are there other techniques?
19 replies so far
View johnstoneb's profile
johnstoneb
2994 posts in 2257 days
#1 posted 01-30-2014 02:39 PM
I don’t know how a biscuit jointer would do that as you need a flat surface for the jointer. The joint would not be very strong
-- Bruce, Boise, ID
View lepelerin's profile
lepelerin
495 posts in 2409 days
#2 posted 01-30-2014 05:28 PM
ask your teacher.
View MisterBill's profile
MisterBill
411 posts in 2336 days
#3 posted 01-30-2014 05:41 PM
I am not sure if this is what you are trying to do but can you use a forstner bit drill a mortise into your flat board and then shape a round tenon on the end of your round leg?
HarveyDunn
#4 posted 01-30-2014 05:46 PM
The round leg is vertical. The rectilinear stretcher is horizontal. I want to joint them at a right angle. The traditional way of doing this – the only way our instructor will teach us – is to leave the turning blank square at the spot where the joint will be.
Like this random photo I found on Google images:
I’d like to know if there is an alternative that does not require the blocky parts.
View Randy_ATX's profile
Randy_ATX
879 posts in 2526 days
#5 posted 01-30-2014 06:23 PM
This image from sawmillcreek would be how I would try it.
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
View dhazelton's profile
dhazelton
2786 posts in 2381 days
#6 posted 01-30-2014 07:02 PM
Why not just make a mortise the full size of the stretchers cross section? You’d have to fasten the round leg to something square so you could turn it a perfect 90 degrees.
View richardwootton's profile
richardwootton
1699 posts in 2039 days
#7 posted 01-30-2014 07:52 PM
I like Randy’s sliding dovetail idea.
-- Richard, Hot Springs, Ar -- Galoot In Training
richardwootton
#8 posted 01-30-2014 07:53 PM
However it does look like it would be hard to cut that by hand…
View Hammerthumb's profile
Hammerthumb
2877 posts in 2059 days
#9 posted 01-30-2014 08:20 PM
Back cut the tenon shoulder at an angle that will allow the faces of the stretcher to meet the round leg with no gaps.
-- Paul, Las Vegas
View Jorg Zimmermann's profile
Jorg Zimmermann
24 posts in 1691 days
#10 posted 01-30-2014 08:21 PM
Similar to the dovetail idea, you could make a groove acording to the dimensions of the stretcher that would create a flat surface on the bottom of the groove and there you either use a mortise joint or dovels.To insert the stretcher into a groove is actually a stronger joint than what you learned.
-- Jorg
View Jeremy Greiner's profile
Jeremy Greiner
568 posts in 2856 days
#11 posted 01-30-2014 08:41 PM
Dowels
With the appropriate jig (ie just a simple 45 degree block/center finder jig) on the drill press you can drill the holes into the leg, then using dowel centers you can imprint the dowel positions on the stretcher.
Then drill the holes in the stretcher, I’d drill extra deep than needed because we’ll be sanding away part of the stretcher.
Then using a spindle sander, I would sand the edge of stretcher so that it would conform to the leg.
-jeremy
-- Easy to use end grain cutting board designer: http://www.1024studios.com/cuttingboard.html
View LakeLover's profile
LakeLover
283 posts in 2024 days
#12 posted 01-30-2014 08:54 PM
View JayT's profile
JayT
5759 posts in 2295 days
#13 posted 01-30-2014 09:05 PM
The first thing that popped into my head was to make the mortises the full size of the stretcher, like dhazleton suggested. You’d have to be very precise in your mortises to give them enough strength, though.
Then had a second, similar idea. Start by making a shallow full size mortise then treat that mortise as the flat of a square leg and create the mortise and tenon joint inside of it. That would give the strength of the shoulders to your joint. It would be tough to do accurately, but should give the desired results.
Here’s a quick Sketchup that shows what I’m thinking.
Don’t know why it wouldn’t work, but that also might be why I’m not a professional furniture builder :-)
Hammerthumb
#14 posted 01-30-2014 09:12 PM
Like your idea JayT but think that making the shoulders of the tenon match the radius of the leg would be easier. If it was me making it, I would just make a small flat on the round leg. After assembly no one would know the difference.
-- Paul, Las Vegas
View JayT's profile
JayT
#15 posted 01-30-2014 09:16 PM
You mean like this? It’s what I was thinking, but was afraid it wouldn’t show up well in Sketchup, so exaggerated it in the first pic. Probably exaggerated it too much.
Just trim off a bit of the radius with a chisel and flatten it out, then mark and chisel out the mortise. Once one joint is done, you should be able to use the stretcher as a reference to make the other side square.
