Storage table hinge question
Forum topic by GussieG posted 01-29-2014 05:08 PM 1978 views 0 times favorited 4 replies Add to Favorites Watch
View GussieG's profile
GussieG
2 posts in 1697 days
01-29-2014 05:08 PM
Topic tags/keywords: question hinge table
I posted this on the GardenWeb woodworking forum, as i often visit other forums on GardenWeb. Realized I might get tons more input here on Lumberjocks…
I am planning to build a long, narrow wooden table that will go between the sofa and the wall. It will be 26” tall, 16” deep and 111” long. To make it easier to maneuver, I plan to construct it in three sections of 37” in length.
I would like for each of these 37” sections to have a hinged top so I can use the space behind the sofa/under the table for storage. I plan to use flush-mount ring pulls right near the sofa back to open the 37” table tops, and I will factor in some small notches in the table top edge for lamp cords.
I thought the hinge would be an easy thing. At first I thought of a piano hinge with some sort of stay that will prevent the table top from slamming closed, but I don’t want the table top (when closed) to have space between the sofa back and the wall so a piano hinge will not work. Right?
Is there a hinge that would work in this situation? Once I find a hinge, I can better figure out the construction of the table support.
Thanks in advance! I am ready to finalize my plans so I can get started on the build.
Gus
View NoLongerHere's profile
NoLongerHere
893 posts in 2793 days
#1 posted 01-29-2014 09:24 PM
ok, I’ll swing at it.
a piano hinge would work if you used a 1 1/2” x 3/4’ cleat laid flat against the wall on top of a full length 1×4 nailer under it. The cleat and piano hinge would give you a little angle in the open position, eliminating the lid stays.
If you don’t want to see anything but an 1/8” space from the wall, you could install the 1×4 nailer and mount pocket hinges with a 3/4 overlay. Not in love with this idea, especially with a pine cleat but it works.
I’d just drill thumb holes and route them round…save your money on the ring pulls. why high light it?
uh…..how are you supporting the front?
View Lee Barker's profile
Lee Barker
2170 posts in 2967 days
#2 posted 01-29-2014 09:38 PM
Well, ahem, I happen to have these hinges for sale. They do what you’re asking:
http://lumberjocks.com/topics/55562
Kindly,
404 - Not Found
2544 posts in 3086 days
#3 posted 01-29-2014 11:43 PM
Assuming this is a conventional table with legs and an apron running around it you could make an L shape rear apron with a slight chamfer to hold the piano hinge and it would allow an overhang on the top.
If the top does overhang you could just lift the flaps by lifting at the overhang on the front.
GussieG
#4 posted 05-23-2014 05:24 PM
Wow. Sorry I disappeared for so long, but life got in the way. I am finally starting to build the tables this weekend. Figure I’ll start with building one of these tables, adjust as necessary, and go from there.
Right now the plan is to build a small apron under the top, which would allow me to use hinges like Lee is/was selling. Mark, good call on the ring pulls. I have scrapped that idea. I just plan to reach under the tabletop to open the “lid.”
As you can likely tell, I am a beginner. And I don’t have much room to work. I figure this should be a good learning experience if nothing else.
Gussie
