| Forum topic by KBC | posted 1605 days ago | 4425 views | 1 time favorited | 11 replies | ![]() |
1605 days ago |
The model isn’t all that old but the unit just isn’t staying at the 0 degree set.The factory setting(when you pull the lever on the top forward and release at the apparent 90 degree setting) it is off by almost 1/8 inch from the fence to full cut. Does anyone know how to fine tune the setting for this saw? I’ll be posting pictures later today(Dec 29) Thanks in advance. -- Ken, Northern Illinois,kbcmtndewman40@yahoo.com |
11 replies so far
#1 posted 1605 days ago |
Ken, What’s the model number on the saw? On mine there are 3 set screws at the top of the column on the back side of the arm that release the head to pivot on the column. Once the arm is set at 0 deg, it holds pretty well provided the screws are tightened appropriately. I’ve found that it’s better to tighten each one a little bit rather than cranking down on one at a time which may make the head move a bit. You indicate that it won’t stay at 0 degrees. Have you been able to get it set properly and it changes or you’ve never been able to get it to 0? If you’ve set it and it moves, there may be indentations on the column where the set screws contact it and it’s moving it back into those rather than staying where you put it – path of least resistance and all that. You may also find that your saw has a preference for going to 0 from one side or the other. Have you tried going to a full stop from both sides to see if one of them does, in fact put the arm at 0 degrees? If so, there may be some slop in the index plate at the top of the column for your 90 degree set. The problem you’re dealing with now is the bane of the radial arm saw. They work great when they’re aligned but getting them that way is a real pain in the . . . ear. Good luck. Whit -- Even if to be nothing more than a bad example, everything serves a purpose. cippotus |
#2 posted 1605 days ago |
#3 posted 1605 days ago |
FYI – Your pictures are not “showing up” when I open your blog. -- Only the Shadow knows.................... |
#4 posted 1605 days ago |
Hmm, they are opening for me,I can’t see the problem on my end,sorry, I would like any advice I can get about adjusting the saw. -- Ken, Northern Illinois,kbcmtndewman40@yahoo.com |
#5 posted 1605 days ago |
Ken, Looks like the only photo you’re missing is the back of the arm where it connects to the post. This saw looks very similar to mine. Check the backside of the arm. There should be a small slot that provides access to 3 setscrews. That’s where you need to make the adjustment. Check the model number, too. You can go to www.craftsman.com and order a manual from them. Whit -- Even if to be nothing more than a bad example, everything serves a purpose. cippotus |
#6 posted 1605 days ago |
The back of the unit is solid plastic,that’s why I didn’t add the pic. I am thinking(again…got to stop the stuff!) the 2 bolts which show in the front of the arm have to be accessible from the rear,I am thinking the 2 screws on the top need removed to be able to remove the rear plastic cover. Fingers (and eyes) crossed. Thanks for the info every one,will re post and tell all( or replace the saw!!!:( ) -- Ken, Northern Illinois,kbcmtndewman40@yahoo.com |
#7 posted 1605 days ago |
Get the manual. Setting up a RAS is not an easy task. Missing one step can make the saw inaccurate and sometimes dangerous. The steps go something like this.
Every saw has different methods of achieving this but the order is the same. Be gentle with the saw. You don’t want to knock it out of whack after spending an hour aligning it ;) -- Scott - Chico California http://chicowoodnut.home.comcast.net |
#8 posted 1604 days ago |
OK,I took the back off( after I found the slot I also found screws,unnoticed at first glimpse..hmmm) and the 3 set screws(Allen sets) just peaked out asking for adjustments!( Just as you said whit!) It took all of 3 minutes to do the fine tuning. The system is 90 degrees by 90 degrees and is even back to the correct marks for measurement from the blade(I have marked the fence for quick reference) Thanks for all the advice,,now I could probably help another person do their unit as well..ahh, the great minds in LJ’s site have done it again! -- Ken, Northern Illinois,kbcmtndewman40@yahoo.com |
#9 posted 1604 days ago |
Great, Ken. Now that you’ve done that, you’ll probably want to go back and check caster and camber of the gimbal. They shouldn’t have changed but with the radial arm saw and all of its various adjustments, changing one can (and often will) change the others. If they’re not all true, you can end up with an out-of-alignment blade that will either make really crappy cuts or bind up and all sorts of nasty things can happen – particularly if you use the saw for both cross-cutting and ripping. The cool thing is, with a bit of practice, you can get the alignment process down to about an hour. ;) -- Even if to be nothing more than a bad example, everything serves a purpose. cippotus |
#10 posted 1587 days ago |
Hey KBC, I have a 20 year old Craftsman radial arm saw too, I can’t find the link that I found to download the manual in “pdf” format. I do have it on my hard-drive and I can forward it to you if you’d like. The file is 2.8Mb, so I’m not sure what the file size limit is but it should go. Let me know.. later, parkerdude -- dust control |
#11 posted 1587 days ago |
Thanks parkerdude,I have found the set screws and finally I am making 90 degree cuts again(the allen head screws were hidden in the rear of the main post,it took longer to write in to the site than it did to adjust the saw to it’s proper setting. Thanks for responding,I think I have it!! Ken -- Ken, Northern Illinois,kbcmtndewman40@yahoo.com |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
223 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1533 |
3550 |
15787 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
