Record 60 1/2 low angle bp assembly question
« back to Hand Tools forum
Forum topic by fazhou posted 01-29-2014 02:07 AM 1732 views 0 times favorited 4 replies Add to Favorites Watch
View fazhou's profile
fazhou
13 posts in 1464 days
01-29-2014 02:07 AM
Hello all,
Does anyone know how the brass knob is attached to the blade adjustment screw on the 60 1/2 block plane? I’d like to eliminate some backlash but would need to remove the brass knob from the screw. There are no visible pins. I doubt it is glued. My wife speculates that it my be an “interference thread” fit or class 4 fit (she’s a machinist). I don’t wanna start reefing on it unless I know. Any ideas?
View exelectrician's profile
exelectrician
2327 posts in 2299 days
#1 posted 01-31-2014 06:29 AM
Backlash is just par for the course. Just learn to live with it, after a while you will enjoy backlash, along with the wonderful sound, and the marvelous curls that swoosh off the blade.
Then there is the satisfaction of a glass smooth finish the blade leaves on your work, and when you crawl into bed after a long day at the bench, you relive all the joy hand planing brings, while your aching muscles remind you, this is reality.
-- Love thy neighbour as thyself
View Don W's profile
Don W
18560 posts in 2439 days
#2 posted 02-01-2014 12:47 PM
Are you sure its not pressed on?
fazhou
#3 posted 02-01-2014 04:21 PM
Don, I’m not sure if it’s pressed on but that makes sense. If it was, do you think it would be prudent to separate them? If I did, could they be attached again very easily? Exel, I am well versed in the aches, sweet sound, and smooth finish associated with a sharp well adjusted plane. I still don’t like the backlash.
Don W
#4 posted 02-01-2014 05:38 PM
I’ve never had a Record, but if it’s like a Stanley, I don’t see what is to be gained. Maybe a picture of what your trying to do. If its pressed on, I wouldn’t try to remove it.
