SANDING SHEET CUTTER
Forum topic by Kelly posted 01-28-2014 07:17 PM 1530 views 0 times favorited 10 replies Add to Favorites Watch
View Kelly's profile
Kelly
2001 posts in 2909 days
01-28-2014 07:17 PM
Topic tags/keywords: sanding sheet cutter sandpaper cutter sand paper cutter
Like many, I have hundreds of sheets of sandpaper that must be cut to fit my 1/4 sheet sander. Using scissors is a slow option and a paper cutter is only marginally better. About thirty years ago, some magazine posted this simple, but efficient cutter and i have been using it ever since.
All it requires is a scrap piece of sheet stock a few inches wider than (a little more than the width of a hack saw blade) and about the same length as a sanding sheet, a hack saw blade, two screws and a couple washers.
To make it:
1) Lay a full sheet of paper on the sheet stock and trace around it with a felt tip. When positioning the paper, leave enough room on each side to mount the hack saw blade, in step 3).
2) Measure half way down the long dimension and draw a line, which cuts the outline of the long dimension of the sheet in half.
3) Mount the hack saw blade with a flat washer on each side, between it and the sheet stock. The blade teeth should be on the line which dissected the outline.
4) Slide a full sheet under the blade so it lines up with your initial outline. Pull down from a corner so the paper is torn by the blade, producing a sheet exactly half the original length.
5) Turn one of the torn sheets over, measure for half the longest dimension and mark a line across.
6) Slide the marked sheet under the blade, with the line showing and the grit against the sheet material until the line lines with the hack saw teeth. Now draw another outline on the sheet goods around the bottom of this piece.
When done, for all future cuts:
1) Slide a sheet of paper, grit out, under hack saw blade, lining it with the full sheet outline and pull down, at an angle across the blade teeth.
2) Spin the cut sheet ninety degrees and align it with the half sheet outline and pull down again.
10 replies so far
View cabmaker's profile
cabmaker
1720 posts in 2774 days
#1 posted 01-29-2014 01:12 AM
Very clever but I mostly use round these days. Thanks JB
View DKV's profile
DKV
3940 posts in 2469 days
#2 posted 01-29-2014 01:20 AM
I can cut multiple sheets on my paper cutter…I would leave you in the dust.
-- This is a Troll Free zone.
Kelly
#3 posted 01-29-2014 02:24 AM
DKV, I can only cut two or three at a time with this. I found variations of this and they put a board under the first cut line, which sped up its use, I suspect. I know I can knock out ten sheets in about a minute or less, so you wouldn’t leave me in the dust by much.
The only time I used my paper cutter with sandpaper was to sharpen it. In the end, there wasn’t enough gain, if any, to make spending the money worth while. You might be surprised at how quickly this makes little papers out of big ones.
In the end, I never have to look for this, it takes up little room and it’s very cheap. If I take it or its brother to a job, I won’t feel real bad leaving it behind.
View Glen Peterson's profile
Glen Peterson
556 posts in 3021 days
#4 posted 02-01-2014 02:16 AM
Hi
I wanted to respond to your thread by showing a sandpaper cutting jig I’ve been using for years. I posted it as a project because it was easier to show that way than add photos to your thread. It’s designed to cut sheets into sixths for hand sanding. The idea came from a magazine but I made it so long ago that I can’t remember which. It has fences that automatically set the cut. Thought you might find it interesting.
Cheers
-- Glen
View Rick's profile
Rick
9432 posts in 2998 days
#5 posted 02-06-2014 02:39 AM
Hey Glen:
Had a look at your Cutting Jig. Good Stuff!
I dragged the LINK here in case anyone else wants to have a Look See.
NOPE! They’re giving me an OOPPS PAGE.
Try This: http://lumberjocks.com/projects/96437
-- LIFE is what happens when you're planning on doing Other Things!
woodbutcherbynight
4338 posts in 2374 days
#6 posted 02-06-2014 03:00 AM
Nice set up. Myself I got one of these from a school that closed, free was something I could not pass up. (laughing)
Kelly
#7 posted 02-06-2014 03:16 AM
Woodmurder, being the nice guy I am, I’m gonna give you a chance to triple your investment. Of course, I presume it comes with Amazon Prime shipping…..
woodbutcherbynight
#8 posted 02-06-2014 03:19 AM
+1 kelvancra ...... Woodmurder???? ROFL
View April Wilkerson's profile
April Wilkerson
117 posts in 1543 days
#9 posted 02-06-2014 04:27 AM
Very cool. It’s going on my list of things to make next.
-- Wilkerson
View Knothead62's profile
Knothead62
2584 posts in 2926 days
#10 posted 02-06-2014 11:58 AM
Cheap scissors- I’m in no hurry. Or a straight edge and a razor knife with a used blade.
