Type of Mask/Filter for spraying lacquer
Forum topic by DeputyMike posted 01-28-2014 02:09 PM 3626 views 0 times favorited 3 replies Add to Favorites Watch
View DeputyMike's profile
DeputyMike
69 posts in 3019 days
01-28-2014 02:09 PM
Topic tags/keywords: spray lacquer filter mask
I cannot for the life of me find any good information online about what I need to use to spray lacguer! Can any of you please tell me what a good mask and what type of filters I need to use?
Thanks!
Mike
3 replies so far
View JAAune's profile
JAAune
1772 posts in 2191 days
#1 posted 01-28-2014 11:06 PM
Go to a paint store and ask for an organic vapor respirator. If you are clean-shaven, a half mask is perfectly fine. People with beards are best off using full masks.
The filters will use activated carbon and are typically covered by a paper or cloth prefilter.
Here is a link to the one I’m using: 3M Organic Vapor Respirator.
View Whiskers's profile
Whiskers
389 posts in 1902 days
#2 posted 01-28-2014 11:42 PM
The 3m masks work fine and are comfortable. The paperwork with the masks and filters you get have some nearly useless info on the type of filters 3m offers but there is also a toll free number you can call and hopefully they can tell you which filters to use for specific chemicals.
View Nicky's profile
Nicky
695 posts in 3966 days
#3 posted 01-29-2014 12:14 AM
Take a peek here for a “quicky” explanation
http://tip.frikafrax.com/2011/01-3217/proper-respirator-for-spraying-solvent-based-paint.html
Then, go to the manufacturers website and look for the Materials Safety Data Sheet, also known as the MSDS. This document will spell out the proper filters required for working with the product. Here is an example.
http://pc.dupont.com/dpc/en/US/html/visitor/common/pdfs/b/product/dr/MSDS/US_en_GNRC_2-1_RFN.pdf
When you know what type of protection is required, then finding the solution is easy.
A lot of variables here….
Are you spraying a small project, with a spray can outdoors? Are your spraying many pieces in a confined space? Your OP is too open ended to give a proper response. A little more detail would be helpful and get you the response you’re looking for.
-- Nicky
