Help understanding this Band Saw terminology
Forum topic by ohtimberwolf posted 01-28-2014 01:10 PM 1041 views 0 times favorited 6 replies Add to Favorites Watch
View ohtimberwolf's profile
ohtimberwolf
750 posts in 2262 days
01-28-2014 01:10 PM
Topic tags/keywords: 1014 tpi
What does this mean in a blade description? It has to do with the teeth per inch but past that I don’t know.
10/14tpi VR
-- Just a barn cat, now gone to cat heaven.
View pmayer's profile
pmayer
1017 posts in 2975 days
#1 posted 01-28-2014 02:20 PM
I believe it breaks down like this:
10/14 tpi = variable tooth size and spacing, ranging from 10 – 14 teeth per inch
VR = variable raker, which is some sort of an optimized a tooth set pattern
ohtimberwolf
#2 posted 01-28-2014 02:53 PM
Strange, not sure what the reason for that would be especially for doing resaw.
View REO's profile
REO
928 posts in 1983 days
#3 posted 01-28-2014 08:33 PM
even a wood blade under the right circumstances like the cross grain pattern matching the tooth spacing can set up a harmonic that will leave an extremely rough finish or throw off tracking.
View jumbojack's profile
jumbojack
1673 posts in 2533 days
#4 posted 01-28-2014 08:50 PM
less vibration from blade harmonics. less vibration=fewer and shallower chatter lines in your cut.
View MrRon's profile
MrRon
4639 posts in 3153 days
#5 posted 01-28-2014 09:33 PM
The only place I’ve seen 10/14 TPI blades is on metal cutting blades. I believe the designation should be VP, not VR.
View Wildwood's profile
Wildwood
2242 posts in 2044 days
#6 posted 01-28-2014 09:40 PM
Saw 10/14tpi VR, on box of band saw coil that cost over $1,000 do not know if metal or wood cutting blades.
-- Bill
