Drawer widths with certain slides?
Forum topic by Brett posted 01-28-2014 03:32 AM 1000 views 0 times favorited 5 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2710 days
01-28-2014 03:32 AM
I am building a tool cabinet with several drawers that will be almost 24” wide. I want to use full-extension slides, (Accuride 3832, 20” long) but the specifications say the slides can be used on drawers only up to 16” wide. How seriously should I regard this max-width limitation? What other options do I have?
-- More tools, fewer machines.
5 replies so far
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1754 days
#1 posted 01-28-2014 03:38 AM
You will be OK. The guides will still work fine. Maybe be a little more wobbly going in, you’ll just have to make sure you push them in straight and from the center.
Make you a little mach up and see how it works for you first.
View Grandpa's profile
Grandpa
3259 posts in 2702 days
#2 posted 01-28-2014 03:40 AM
I agree. As long as the drawer is stiff and you watch the weight limit you will be okay.
View GrandpaLen's profile
GrandpaLen
1650 posts in 2299 days
#3 posted 01-28-2014 03:45 PM
Brett,
Drawer slides are weight rated, to include the weight of the drawer materials. If you do not surpass the weight limit and your drawer is stiff enough to not sag, your slides won’t know how wide your drawer is.
Work Safely and have Fun. – Grandpa Len.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View skipj's profile
skipj
97 posts in 2299 days
#4 posted 01-28-2014 08:38 PM
Len is correct.
Dresssr 30” wide
Pantry cab. 28”
Slides are the 20” 3832
View oldnovice's profile
oldnovice
6901 posts in 3395 days
#5 posted 01-29-2014 08:12 AM
I used Accuride ball bearing slides 18” long on a 27-1/2” wide set of 7 drawers of various heights without any problem. I also used the Fulterer brand (an Accuride direct replacement) in a similar application without any problems.
Other than getting the drawer started when first inserting the drawer into the mounted slides I do not know why they have that mentioned in their specifications!
