Best router speed for dovetailing
« back to Joinery forum
Forum topic by keninblaine posted 01-27-2014 08:10 PM 1710 views 0 times favorited 11 replies Add to Favorites Watch
View keninblaine's profile
keninblaine
130 posts in 1570 days
01-27-2014 08:10 PM
I’m making a second attempt to make dovetail joints in 1/2” baltic birch plywood. I just acquired a variable speed PC router. Does anyone know the best speed for using 14 degree 3/4” dovetail bits?
-- Ken, Blaine Washington
11 replies so far
View Dallas's profile
Dallas
3599 posts in 2455 days
#1 posted 01-27-2014 08:44 PM
Slower is better. You are using a backer board aren’t you? If not the plywood will blow out.
Good Luck.
View bladeburner's profile
bladeburner
88 posts in 3055 days
#2 posted 01-27-2014 09:10 PM
You picked a tough board to start on, but I agree with Dallas. See if 12k will cut w/o chatter. At any rate…Good Luck and try to keep a sense of humor!
keninblaine
#3 posted 01-27-2014 09:41 PM
Thanks guys. I’m going to have a board clamped to both sides, and will try 12000 rpm. Wasn’t sure if it was better to go faster or slower on bit speed.
View ajosephg's profile
ajosephg
1880 posts in 3529 days
#4 posted 01-27-2014 09:47 PM
I disagree. With that size bit, you should go as fast as you can but feed real slow.
The most important thing is to use a really sharp bit.
-- Joe
keninblaine
#5 posted 01-27-2014 09:51 PM
ajosephg: My intuition told me that faster would be better. I’ll experiment on some scraps and see what works best on my wood. Thanks.
View PurpLev's profile
PurpLev
8534 posts in 3616 days
#6 posted 01-27-2014 09:54 PM
speed should be related to router bit size, not application. usually with router bits you want to run them as fast as possible – with the exception (and this is where you’d want to slow things down) of large bits such as raised panel and the likes which would benefit from slower speed due to a larger cutter area and much much higher cutter speed at it’s widest point.
View teejk's profile
teejk
1215 posts in 2652 days
#7 posted 01-27-2014 10:05 PM
Are you using a jig? If so I think I have to agree with Joe. My Leigh has gotten a lot use lately and I think I have (finally) figured out the proper technique using my single speed PC 690’s to avoid chip-out. I learned to “sneak-up” on any of the cuts so more like “shaving” than “cutting”. The bits stay pretty sharp but periodic cleaning to remove pitch works wonders (carb cleaner and a light touch against the wire brush is what I do).
keninblaine
#8 posted 01-28-2014 02:05 AM
Thanks guys. BTW, I received my PC 892 router today. My 1 3/16” router guide (5/8”) won’t fit in the base since the hole is over 2” in diameter. Is it possible to get guides that will fit this base?
ajosephg
#9 posted 01-28-2014 03:39 AM
Sounds like you don’t have a sub-base for the router
http://www.rockler.com/guide-bushing-router-plate
-- Joe
keninblaine
#10 posted 01-28-2014 04:23 AM
ahosephg: yeah, I figured that out a short while ago, and ordered one on line tonight.
Thanks
View pintodeluxe's profile
pintodeluxe
5623 posts in 2781 days
#11 posted 01-28-2014 06:51 AM
I use speed 4.5/6 on my Dewalt 618 for cutting 14 degree dovetails. Too slow will bog down the motor, and too fast can leave some chipout. I never run it at full tilt for dovetails. I slow dovetails down because dovetails must be cut in a single pass.
I wouldn’t use plywood for dovetails though. I think you will have better luck with solid wood like poplar.
