Need help, advise with my 14'' TradeMaster Bandsaw where blade goes threw table guide hole?
Forum topic by Jim Reeves posted 01-26-2014 04:36 PM 3501 views 0 times favorited 2 replies Add to Favorites Watch
View Jim Reeves's profile
Jim Reeves
208 posts in 3021 days
01-26-2014 04:36 PM
Hi, hoping some one can help me, l bought a 14’’ TradeMaster Bandsaw a few years ago have not used it was in storage. Went to remove the 3/8’’ blade to put on 1/2’’ blade thinking could do more with it.
Turned out couldn’t get it so my friend come over set up bandsaw leaving 3/8’’ blade in it. But when l start bandsaw where it goes down threw the table metal insert guide hole, l think blade is touching the side of the metal guide insert.
Is there suppose to be a space between the side of the blade and the sides of the table insert metal guide ?
My bandsaw didn’t come with a manual and have had no luck downloading one, TradeMaster l called them said they were sending me a manual and a miter guage but was 6 months ago.
I hope l explained the above well enough.
Thanks Jim, Ontario, Canada
-- jim
2 replies so far
View lew's profile
lew
12056 posts in 3753 days
#1 posted 01-26-2014 05:03 PM
Jim,
My metal guide has the slot slightly off center- i don’t know why. Maybe yours is the same. If you flip the guide over, would that correct the problem??
EDIT: This might be the manual you need
http://makingsawdust.org/blog/wp-content/uploads/2012/07/TM13207_IN13210-manual-Eng-2.pdf
Jim Reeves
#2 posted 01-27-2014 03:51 AM
Thanks Lew for idea of flipping it over and link will try it shortly thanks so much
jim
-- jim
