5 Days of work on my first cutting board, then disaster!
Forum topic by Steve Kreins posted 01-26-2014 02:14 AM 2454 views 0 times favorited 26 replies Add to Favorites Watch
View Steve Kreins's profile
Steve Kreins
358 posts in 1683 days
01-26-2014 02:14 AM
Topic tags/keywords: humor tip question planer milling sanding explosion
Disaster stuck my shop tonight! After five days of work on my very first cutting board it EXPLODED! Seriously! The darn thing exploded! Have you ever had a cutting board explode?
Here’s what I think happened. I was down to rough sanding it when I got in a hurry. After all, I’ve spent a lot of time watch glue dry. So I had this brilliant idea. Why do all this work with the sander when I’ve got a brand new planer sitting on the bench. I did some practice runs with it so I’m a pro. Right? I had one side fairly even but the other side had high spots, a bunch. But surely my planer would make quick work of that.
First pass I took less than 1/16” cut. It went through smooth as silk. I flipped the board over and started my second pass. BOOM! The proverbial pigeon poop hit the fan and chunks of wood EXPLODED in every direction. I had no idea woodworking could be this exciting. After I showered and changed my underwear, I went back and picked up the pieces.
Here’s what it looked like after the first glue up before the second cut to expose the end grain.
Here’s what it looks like now.
Maybe I can salvage enough to make an apple slicer board.
  • FOLLOW UP REPORT: 1/26/2014
NCIS, I’m a Navy Veteran, completed their forensic exam and came to the following conclusions:
1. My table saw blade and fence need adjusting
2. This led to uneven and not parallel cuts.
3. The glue was sufficient, but not so much so that compression could make up for the gaps.
4. I could have gotten away with using the planer if both sides were sanded smooth and level, but then I wouldn’t have needed the planer.
5. Haste makes waist.
6
The cancer isn’t as likely to kill me as my lack of shop safety.
7. Changing my underwear was the only thing I did right.
Conclusion: NCIS recommends that I go back to Vietnam, I’ll be safer.
-- I thank God for everything, especially all of you!
26 replies so far
View Randy_ATX's profile
Randy_ATX
879 posts in 2494 days
#1 posted 01-26-2014 02:19 AM
You need a drum sander to safely do what you attempted with an endgrain cutting board. I’d never attempt putting one in a planer for the reason you discovered. Glad you are okay.
-- Randy -- Austin, TX by way of Northwest (Woodville), OH
View Kryptic's profile
Kryptic
294 posts in 1713 days
#2 posted 01-26-2014 02:23 AM
God Speed
View pwalter's profile
pwalter
79 posts in 2637 days
#3 posted 01-26-2014 02:33 AM
Glad you are alright. You may want to check your planer blades. I have heard of the blades ending up damaged when someone does what you did.
View Betsy's profile
Betsy
3391 posts in 3948 days
#4 posted 01-26-2014 02:40 AM
I put my end grain boards through the planer all the time. In fact, I planned 10 boards last night with no issues. The trick is to take very tiny bites, have good knives and round over the back edge to prevent tear out. Patience doesn’t hurt. I’m not going to say it won’t ever happen but I have not had any issues.
Interestingly, the only blow out I have had was a piece of very plain grain maple. I got lucky and was able to get the isdue taken care of.
Long and short, planing my end grain boards saves ne a ton of time sanding.
I’m glad you were not hurt. I would cut you board down and use it as a board to cut limes for a refreshing beer.
By the way, the smallest end grain board i will put through the planer is 10” in length. Anything shorter goes through the drum sander.
Good luck.
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
Kryptic
#5 posted 01-26-2014 02:50 AM
tip of the day
try a router
and sneak up on it
View wseand's profile
wseand
2796 posts in 3094 days
#6 posted 01-26-2014 03:22 AM
You have to be careful when using a Planer, you should only take about a 32nd or shallower pass.
I use my planer and take very shallow passes but it really isn’t recommended.
I’m guessing you won’t be trying it again though.
Kryptic
#7 posted 01-26-2014 03:25 AM
router
doh
Kryptic
#8 posted 01-26-2014 03:28 AM
its like a grenade ?
boom go the lights of the dream of the perfect cutting board ?
thin, very thin end grain
u sneak up on it,
or
BOOM
glue it to substrate of some kind first
Kryptic
#9 posted 01-26-2014 03:29 AM
some things
cannot be put through the planer without thought
Kryptic
#10 posted 01-26-2014 03:34 AM
glue the shit down to a substrate, be it another layer of the same pattern repeated ?
as a collective ? if we buy plywood layered in sheets of veneer ?
would we reinvent how to make plywood “
one is is inexpensive,
yours ?
not so much
Kryptic
#11 posted 01-26-2014 03:36 AM
it would be seldom, when I put plywood, through a planer, if for 1 reason
it lacks common sense
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1780 days
#12 posted 01-26-2014 03:40 AM
Here’s what I think happened!
You have to have better glue joints.
I don’t know what happened, but your joints aren’t very tight at all. (Red Circles)
Look at how clean the breaks are (Blue Circles) Not enough glue penetration. Maybe not enough glue?
View alohafromberkeley's profile
alohafromberkeley
257 posts in 2457 days
#13 posted 01-26-2014 03:45 AM
Steve,sorry about your cutting board but I’m glad you came out unscathed. BTW, I liked the look of the long grain glue-up and probably would’ve been satisfied with it at that point.
-- "After a year of doing general farmwork, it was quite clear to me that chickens and I were not compatible"-George Nakashima
View Radu's profile
Radu
330 posts in 3096 days
#14 posted 01-26-2014 03:57 AM
Sorry your cutting board went kaboom. You might want to check your planer so you don’t have any surprises latter. I really enjoyed reading this section “After I showered and changed my underwear, I went back and picked up the pieces.” It really scared you, eh?
wseand
#15 posted 01-26-2014 04:02 AM
Good catch Kevin,
Take a pic of the glued surface and see if it looks like there was a insufficient amount of glue.
