How Do You Remove Your Bark
« back to Woodcarving forum
Forum topic by stixman posted 01-25-2014 09:35 PM 1153 views 0 times favorited 7 replies Add to Favorites Watch
View stixman's profile
stixman
62 posts in 3217 days
01-25-2014 09:35 PM
Today, I needed to remove the bark from a couple of curled sticks, before I carve on them.
The pressure washer can make the difficult job of removing bark from the stick, easy.
Removing bark video
-- https://kentuckywalkingstick.com/
7 replies so far
View Nicholas Hall's profile
Nicholas Hall
352 posts in 2128 days
#1 posted 01-26-2014 02:03 PM
Bark spud. A bit overkill for your application.
The best toy I saw for doing the job was in a papermill in Hinkley Maine. It’s called a debarking drum. Theirs was a 100 foot long steel cylinder 20ft in diameter. Their were carbide teeth around the inside walls of the drum. The mill sent tree length logs in one end and barkfree logs came out the other end. It was like the world’s biggest rock tumbler. I always thought it would be cool to build a small scale version.
-- Outside of a dog, a book is a man's best friend. Inside of a dog, it's too dark to read. -Groucho Marx
View leafherder's profile
leafherder
1422 posts in 1974 days
#2 posted 01-26-2014 06:12 PM
For my canes and walking sticks, it depends on the wood – knife, rasp, sandpaper, or Dremel. Usually sandpaper – it takes the longest but you never know what interesting colors or patterns will be revealed as each layer is removed.
-- Leafherder
View Monte Pittman's profile (online now)
Monte Pittman
29379 posts in 2360 days
#3 posted 01-26-2014 06:22 PM
Pressure washers work great. Should be 3000 psi or greater though.
View MalcolmLaurel's profile
MalcolmLaurel
298 posts in 1645 days
#4 posted 01-26-2014 11:23 PM
How big a pressure washer was that (how much pressure and flow)? Looks like it could be a great way to prepare my lamps. I currently scrape the bark with a knife, though I’ve also used a sandblaster on a real twisty root piece (I’m not crazy about the sandblasted finish).
-- Malcolm Laurel - http://MalcolmLaurel.com
View JollyGreen67's profile
JollyGreen67
1676 posts in 2785 days
#5 posted 01-26-2014 11:32 PM
Is it louder than a bite ? ;o)
-- When I was a kid I wanted to be older . . . . . this CRAP is not what I expected !
View rustfever's profile
rustfever
752 posts in 3332 days
#6 posted 01-26-2014 11:57 PM
I use several carving tools. One is sharp, wire like and curved, similar to the thing the Dentist uses. The other is similar, but about 3/16” wide.
-- Rustfever, Central California
View thesoninlaw's profile
thesoninlaw
97 posts in 1807 days
#7 posted 01-27-2014 12:05 AM
Steaming works well
