Craftsman router will not start
Forum topic by Mike789 posted 01-25-2014 05:30 PM 1434 views 0 times favorited 11 replies Add to Favorites Watch
View Mike789's profile
Mike789
5 posts in 2133 days
01-25-2014 05:30 PM
Topic tags/keywords: router
I have a Craftsman router and it will intermittently works, meaning I can turn it on 1 time and it works, the next time it will not. I’m not sure what is causing it, my guess is the switch is going bad. The router is roughly 8 to 10 years old. Does anyone have any thoughts what it could be? Would it be better to just go out and purchase a new one or try to fix it?
11 replies so far
View Dallas's profile
Dallas
3599 posts in 2513 days
#1 posted 01-25-2014 05:33 PM
Get another router, or you could buy a can of CRC electronics Contact Cleaner and spay it into your swich while working it back and forth, hither and yon, fore and aft, or port and stabbord.
By the way, what model is it? I junked a few of my old Craftsman routers but saved the switches, collets, lock nuts, base plates etc. I may have one for yours, or someone else here might.
View BigJerryWayne's profile
BigJerryWayne
138 posts in 2128 days
#2 posted 01-25-2014 06:00 PM
I agree with Dallas, contact cleaner could help. May be the brushes also. Spray them with contact cleaner too.
-- An oak tree is just a nut that stood it's ground.
View JustplaneJeff's profile
JustplaneJeff
263 posts in 1929 days
#3 posted 01-25-2014 06:05 PM
check the switch. Had one go bad on myDeWalt, simple fix.
-- JustplaneJeff
View basswood's profile
basswood
261 posts in 1646 days
#4 posted 01-25-2014 06:07 PM
Sometimes there is just some dust in the switch. Blowing compressed air in there may take care of it.
-- http://www.basswoodmodular.com/Tri-Horse-Builder-Plans-p/thbp.htm
View bbc557ci's profile
bbc557ci
595 posts in 2100 days
#5 posted 01-25-2014 06:25 PM
Might wanna check the cord too, where it exits the body of the machine. I’ve had circular saws act the same way, it was cords that wore out where they enter the saw.
-- Bill, central NY...no where near the "big apple"
Mike789
#6 posted 01-25-2014 06:48 PM
Thanks for replying, I will try the cleaner first. My router is Craftsman 130.26620
View Jokker78's profile
Jokker78
136 posts in 1723 days
#7 posted 01-25-2014 07:23 PM
I have one that does that, the brushes were worn out. I bought new ones. I changed them. It works better but still not new. The armature is worn to bad.
-- Measure once, cut , measure again, cut and damn its still to short
View alohafromberkeley's profile
alohafromberkeley
257 posts in 2430 days
#8 posted 01-25-2014 07:53 PM
I’d check to see if the brushes are OK. If they are, then open it up and clean it with compressed air. It sounds like there’s a short in the power cord or on/off switch.
-- "After a year of doing general farmwork, it was quite clear to me that chickens and I were not compatible"-George Nakashima
Dallas
#9 posted 01-25-2014 08:20 PM
Jokker78
Get yourself a welding tip cleaner or some thin tip files and clean the slots in the armature out, very carefully.
If you screw up the armature, you might as well toss the machine.
If the armature slots are full of crud, there is a good possibility that they are shorting out.
Good Luck.
Edit: This is interesting.
http://www.sawmillcreek.org/showthread.php?67264-Sears-Bosch-router-kit-on-clearance-at-Sears
View sawdustjunkie's profile
sawdustjunkie
384 posts in 1743 days
#10 posted 01-25-2014 08:26 PM
I have 2 Craftsman and a few Bosch. The craftsman that went bad had variable speed and the board went out, so I just straight wired it and it works fine. I just don’t have the variable speed.
My other craftsman is still going strong.
-- Steve: Franklin, WI
View knotscott's profile
knotscott
8057 posts in 3401 days
#11 posted 01-25-2014 09:56 PM
Before spraying cleaner in it, try blowing the saw dust out….then spray.
