panel cutters
Forum topic by 3285jeff posted 01-25-2014 03:16 PM 774 views 0 times favorited 3 replies Add to Favorites Watch
View 3285jeff's profile
3285jeff
152 posts in 1712 days
01-25-2014 03:16 PM
Can anyone tell me where I can buy a full sheet plywood cutter like the one lowes or home depot uses!!
3 replies so far
View thesoninlaw's profile
thesoninlaw
97 posts in 1780 days
#1 posted 01-25-2014 04:49 PM
Just google ‘panel saw’ and you will find more than you care to look at.
View RockyTopScott's profile
RockyTopScott
1186 posts in 3473 days
#2 posted 01-26-2014 02:49 AM
Grizzly has one I think.
-- “When you want to help people, you tell them the truth. When you want to help yourself, you tell them what they want to hear.” ― Thomas Sowell
View eltee's profile
eltee
18 posts in 1584 days
#3 posted 01-26-2014 04:26 AM
Are you doing high volume work that requires breaking down dozens of 8×4 sheets quickly? I was looking at the one at my local Lowes today and talking to the guy running it. They’re apparently about as accurate as they look, which is to say about a step up from an ax. They’re designed to give quick, rough cuts to sheet goods and wide boards. It does nothing to flatten the sheet while being cut or measured, so how it’s bowed will affect the accuracy of the cut. Tear out is usually awful because of a total lack of support for the cut… Oh, and they’re HUGE!
Unless you’re, in fact, talking big volume, you’re probably better off with a track saw or even a circular saw with an edge guide.
