Dimensioning oversized lumber
Forum topic by BJODay posted 01-25-2014 03:53 AM 1420 views 1 time favorited 8 replies Add to Favorites Watch
View BJODay's profile
BJODay
526 posts in 1943 days
01-25-2014 03:53 AM
Topic tags/keywords: planer joiner
I’m hoping someone can help me out.
I purchased some 4/4 oak. It is +7” wide. I have a 6” joiner. I would
normally square up 2 edges on the joiner and then plane to thickness.
Can I use a planer to square up the wide dimensions?
Are there inherent problems trying to do this?
I’m not skilled enough to do it with a hand plane. I cannot
purchase an 8” joiner
Thanks for any advice,
BJ
8 replies so far
View Goodsh's profile
Goodsh
80 posts in 1920 days
#1 posted 01-25-2014 04:17 AM
You can use your planer with a sled. My sled is two pieces of 3/4” mdf glued together to make a very rigid surface. Then all I do is use hot glue in a few spots to hold the board down on the sled and keep it in place. Run it through the planer until the top side is flat then take it off the sled, remove the glue, and run it through the planer to flatten the other side. I don’t have a jointer so this is how I do all my face jointing. It takes a while but works until I can afford a jointer. I think there is a trick to doing wider boards with a jointer but I don’t know.
View DKV's profile
DKV
3940 posts in 2504 days
#2 posted 01-25-2014 06:01 AM
What are you building? Does it require the 4/4, 7” wide board? I cut to rough size according to what I’m building and then mill the lumber. Of course, if you need the board the full size and have only a 6” jointer then some magic is required.
-- This is a Troll Free zone.
View pintodeluxe's profile
pintodeluxe
5663 posts in 2814 days
#3 posted 01-25-2014 06:59 AM
Remove the guard on your jointer, and make a pass or two until a ridge develops on the face of your board. Then place the board upside down on a strip of plywood. Overhang the rough part of the board, so the milled section of the board is flat on the plywood strip.
Now run the board and plywood strip through the planer. This will give you one flat face. Then simply flip the board over, and finish planing the other face as usual.
With a 6” jointer you can joint boards up to 9-10” wide with this technique.
View gfadvm's profile
gfadvm
14940 posts in 2690 days
#4 posted 01-26-2014 01:58 AM
Pinto’s advice is spot on! Been there, done that, worked well>
View jasonallen's profile
jasonallen
187 posts in 1621 days
#5 posted 01-26-2014 02:15 AM
Interesting Pinto
-- Skill and confidence are an unconquered army.
View WDHLT15's profile
WDHLT15
1744 posts in 2476 days
#6 posted 01-26-2014 03:55 AM
Pinto is on the money.
View HarveyDunn's profile
HarveyDunn
328 posts in 1731 days
#7 posted 01-26-2014 04:43 AM
Pictures of pintos “big rabbet” trick in FWW #204 if you are interested.
BJODay
#8 posted 01-27-2014 02:39 AM
Thanks for the advice.
BJ
