FLAT GROUND VS. HOLLOW GROUND
Forum topic by JUC posted 01-24-2014 06:41 PM 2390 views 0 times favorited 11 replies Add to Favorites Watch
View JUC's profile
JUC
116 posts in 2132 days
01-24-2014 06:41 PM
I am going to upgrade my sharpening system. I see a lot written about flat vs hollow ground. What do you all prefer and why? I will be sharpening plane blades and chisels for the most part.
Thank you for your time and knowledge!!
Jeffrey
-- If no one will ever see it, all the more reason to make it right
11 replies so far
View Texcaster's profile
Texcaster
1286 posts in 1915 days
#1 posted 01-24-2014 06:55 PM
Flat or hollow would work for me. I use a grinder and start with a hollow grind. When I get to the stones I press the tip flat to find the angle, then lift slightly and hone a micro bevel
-- Mama calls me Texcaster but my real name is Mr. Earl.
View sikrap's profile
sikrap
1121 posts in 3600 days
#2 posted 01-24-2014 07:16 PM
A hollow grind makes it easier to freehand hone (IMHO), but that’s the only advantage I can think of. I use a flat grind and I almost never use a grinder. If I need to bring an iron back into square, I do it the way Deneb shows on one of the Lie Nielsen videos (I believe its Quick Tip #4) which is to stand the iron up vertically and just drag it across sandpaper. Its every bit as fast as a grinder and I don’t have to worry about overheating it. I also have a WorkSharp 3000 that I can use to re-establish a bevel if I want. To actually create the bevel, I either use the WS or I use a 220 waterstone and my MKII jig. Both give me a flat primary bevel and I just adjust the angle for the secondary bevel. HTH
-- Dave, Colonie, NY
View b2rtch's profile
b2rtch
4868 posts in 3290 days
#3 posted 01-24-2014 07:50 PM
If you watch Paul Sellers videos , he recommends (against every one else opinion) a convex surface.
When I was a kid and living in France, all the chisels I ever saw had a convex surface and they worked well.
A convex surface is also easier to achieve and it does require any special equipment.
I used to use scary sharp and after to use diamond sharpening stone and to try very hard to have a perfectly flat surface. I no longer do that.I now use a convex surface and it works very well for me.
-- Bert
View TheGermanJoiner's profile
TheGermanJoiner
847 posts in 1879 days
#4 posted 01-24-2014 08:21 PM
+1 Bert and Paul sellers. Easier to do too
-- Greg - Ferdinand and Son Construction: Do it right the first time. Like us on Facebook
View Don W's profile
Don W
19052 posts in 2809 days
#5 posted 01-24-2014 08:38 PM
I like the hollow grind because its easier to free hand. You also get the advantages of a micro bevel with out a micro bevel. Although after the initial sharpening I usually don’t hollow grind again unless I need the grinder to take out a nick.
b2rtch
#6 posted 01-24-2014 10:33 PM
View JUC's profile
JUC
#7 posted 01-25-2014 12:52 AM
Thanks for the comments and help. I can not find Lie Nielsen video [quick tips #4] on their site. I will keep looking. Bret that was a informative video, thanks.
Just looking for information before I spend the $. We all own tools we wish we and not bought. I really try to keep it to a minimum.Thanks,
Jeffrey
Don W
#8 posted 01-25-2014 12:59 AM
I know there are a zillion sharpening blogs, but I’ve been through most. I simplified. http://lumberjocks.com/donwilwol/blog/24179
Texcaster
#9 posted 01-25-2014 02:12 AM
I micro bevel a hollow ground edge just to avoid honing the heel and stone wear. Also it is easier to camber if I want. I also stop at the hard black Arkansas ( 1000- 1300 grit ). A 60 grit aluminium oxide wheel, dressed frequently cuts fast and cool for me.
sikrap
#10 posted 01-25-2014 02:51 AM
Here is a link to the LN video. Enjoy!!
http://www.youtube.com/watch?v=yogRewlMWrc&list=PL1E4A85B18EB8D8BA&index=9
View JUC's profile
JUC
#11 posted 01-25-2014 07:46 PM
Thank you all so much for all your advise and information.
Dave thank you for the link, I am not much of a computer person. I will look at it tonight. I am in my shop today.
thanks again!!
Jeffrey
