21 mm bit?
Forum topic by Sawdust2012 posted 01-24-2014 06:34 PM 991 views 0 times favorited 7 replies Add to Favorites Watch
View Sawdust2012's profile
Sawdust2012
121 posts in 1675 days
01-24-2014 06:34 PM
I have a turning project that calls for a 21 mm bit. I cant seem to find one anywhere. One site has a 21.3 mm Forstner bit. Is that close enough?
7 replies so far
View mondak's profile
mondak
71 posts in 2363 days
#1 posted 01-24-2014 06:41 PM
Do a search on the net for W L FULLER INC
They manufacture bits etc and will send you to one of their retail outlets.
View Texcaster's profile
Texcaster
1273 posts in 1637 days
#2 posted 01-24-2014 06:45 PM
19mm is also hard to find. I ground a spade bit to suit. I take a deep breath every time I have to use it.
-- Mama calls me Texcaster but my real name is Mr. Earl.
View Tedstor's profile
Tedstor
1643 posts in 2596 days
#3 posted 01-24-2014 06:50 PM
A 13/16” might be easier to find and would be only slightly smaller.
HillbillyShooter
5811 posts in 2255 days
#4 posted 01-24-2014 06:53 PM
Check out Woodcraft—I’ve ordered several miscellaneous metric sizes.
View CampD's profile
CampD
1648 posts in 3449 days
#5 posted 01-24-2014 07:01 PM
The real questions you should ask yourself is; What is this bit needed for? What will be put through the hole?
Will you apply a finish? if so a 21.3 bit would work fine once a finish is applied.
Or else you could just use a 27/32 bit
-- Doug...
View PaulDoug's profile
PaulDoug
1508 posts in 1666 days
#6 posted 01-24-2014 07:12 PM
13/16” (0.8125) (—0.0143)
21mm (0.8268)
Info from: http://www.penventory.com/inv.pl
View WayneC's profile
WayneC
13753 posts in 4060 days
#7 posted 01-24-2014 07:12 PM
