Forum topic by REO | posted 01-24-2014 03:46 PM | 5409 views | 1 time favorited | 30 replies | ![]() |
Topic tags/keywords: lathe turning resource diy bowl lathe Is there anyone interested in building a bowl lathe? I enjoy designing ,building, and using equipment! Any kind of equipment. I have seen several posts where people consider building their own bowl lathe. some take years to get the project done. Some give up and never have the chance to complete it. Most of the time that is lost is either in making mistakes or sourcing parts. I have worked on several of my own project that seems to go very well and then I find that I have made a mistake that will require dis-assembly or starting over, It can be very disheartening. My thoughts for this thread: 1.Gather information and discuss: materials, drives, options, capacity. standardize as much as possible. A bowl lathe is a pretty simple machine. a couple pulleys, a motor, a couple bearings a knee and a tool rest. Any one want to get together on this? |
30 replies so far
#1 posted 01-24-2014 06:11 PM |
Come on people, no interest? don’t believe its possible? |
#2 posted 01-25-2014 01:21 AM |
Roger … I have always been a bit of a gadget freak, so I appreciate your videos and the info in this post. I just can’t see my way clear to get into something of this scale. If I need to turn something big, I have a buddy with a VB-36! -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#3 posted 01-25-2014 11:34 AM |
I haven’t set a size. The lathe shown isn’t a bowl lathe. I posted to give an example of what is possible. It is not difficult. I am trying to facilitate a venue where it could be fairly inexpensive. I also hope it will be a resource to get people up and running in a shorter amount of time. I think it could be completely scalable if properly done. kind of an A,B,C size choice thing. I had seen a frequency of posts about interest in bowl lathes and thought it might be fun. Over 200 “looking” for “something” about bowl lathes. Only one who said anything. I don’t know anyone with a big bowl lathe. I actually don’t know anyone in person with a dedicated bowl lathe of any size. Please excuse the double post. somehow LJ’s must have autosaved before I was done editing and i cant get rid of this one. |
#4 posted 01-25-2014 11:39 AM |
I haven’t set a size. I don’t plan on being an “I” thing. If I did I would draw it up and just offer plans for sale. Hoping on group interaction. The lathe shown isn’t a bowl lathe. I posted to give an example of what is possible. It is not difficult. I am trying to facilitate a venue where it could be fairly inexpensive. I also hope it will be a resource to get people up and running in a shorter amount of time. I think it could be completely scalable if properly done. kind of an A,B,C size choice thing. I had seen a frequency of posts about interest in bowl lathes and thought it might be fun. Over 200 “looking” for “something” about bowl lathes. Only one who said anything. I don’t know anyone with a big bowl lathe. I actually don’t know anyone in person with a dedicated bowl lathe of any size. |
#5 posted 01-25-2014 12:48 PM |
While a lathe is not on my list of machines to build in the near future i always find homemeade machines and tools exiting and often see innovative designs. Would appreciate to follow along on the side as the build progresses! -- "Do or Do not. There is no try." - Yoda |
#6 posted 01-25-2014 05:00 PM |
http://www.finewoodworking.com/tool-guide/article/homemade-lathe-on-a-budget.aspx This one is great! Check it out. |
#7 posted 01-25-2014 05:16 PM |
I talked about it for awhile but two things happened, first I got a bunch of other machinery that I really need more than a bowl lathe and second, I ran out of room in my shop. Someday I may revisit the idea if it’s feasible to build one that can withstand being outdoors. Perhaps build the frame from ipe and other weather resistant hardwoods and either scavenge a headstock/tailstock from a functioning lathe or build them from scratch. -- Rick M, http://thewoodknack.blogspot.com/ |
#8 posted 01-27-2014 04:19 AM |
I’m going to build a lathe and tailstock with at least a 24-30” swing for turning large off center objects. Right now a 12” lathe only allows turning the things I want to 7” maximum….. I’d rather do the larger stuff. -- Jerry (in Tucson) www.woodturnerstools.com |
#9 posted 01-27-2014 02:28 PM |
Nubs you are very fortunate! Most do not have the resources available to them. Last night I was thinking about doing a series of pop on modifications for a jet midi lathe tail stock to get the thread going. This may work as well. I would be happy to put together some 3D concepts for you. If you would like. Size of the bed slot. |
#10 posted 01-31-2014 12:10 PM |
thesoninlaw. do you have the drawings for that lathe? what have you turned on it? |
#11 posted 01-31-2014 03:01 PM |
I do not have drawings for that lathe and I have not turned anything on it—It is someone else’s lathe I happened to see on FWW. |
#12 posted 01-31-2014 04:10 PM |
Roger, -- Julian |
#13 posted 01-31-2014 05:07 PM |
It depends entirely on what you have available to you. If you have to have someone weld or machine pats for you. If you have some of the necessary parts already. The best way to go for |VS is with an inverter drive. locally I can get a 2 hp three phase motor for less than 50 dollars sometimes they are inverter duty. (I have a couple “toy stores” that I frequent. Often they have a VFD for about 125 but they go fast. watching Ebay pillow block bearings can be had for less than shipping some times but I suggest at least a flange bearing and better yet a piloted flange bearing for the headstock. I got two 2” recently for 28.00/pr. I have seen pillow block bearings break in similar set ups.Steel used to be cheap but it has skyrocketed the last few years so I watch Craigs list for stuff. I have my own equipment for machining and welding. This lathe I know what I need and what I am looking for because I have the plans drawn up. The trial and error expense and effort is bypassed. That is why I thought a thread like this could be of benefit. A collaboration of people looking, watching, providing information and answers. We all have tools and equipment that we would like to have. For most of us they are a pipe dream because of cost or limited ability especially if you have to pay for mistakes! I would like this to be a place that makes it possible. With a clear direction and void of potential costly mistakes. |
#14 posted 02-02-2014 03:06 PM |
I’ve been wanting a way to turn large bowls for some time. |
#15 posted 02-02-2014 07:06 PM |
William, my blog has pics/videos of a 1HP DC motor first running a GP lathe then later moved to a Craftsman. Fairly easy to set up and I have schematics for an mc-50 controller (most common type). http://lumberjocks.com/wormil/blog/34487 -- Rick M, http://thewoodknack.blogspot.com/ |
Forum | Topics |
Woodworking Skill Share
12035 |
Woodturning
2109 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1372 |
Finishing
4909 |
6698 |
28076 |
CNC Woodworking
212 |
Hand Tools
5413 |
Jigs & Fixtures
1421 |
Wood & Lumber
6236 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8847 |
