Nightstand Top Attachment
« back to Joinery forum
Forum topic by Todd posted 01-23-2014 06:36 PM 834 views 0 times favorited 8 replies Add to Favorites Watch
View Todd's profile
Todd
398 posts in 1672 days
01-23-2014 06:36 PM
Topic tags/keywords: joining question cherry
Hi All,
I’m building a cherry nightstand and the top on it will be 18”x24”. I know for large tops (like tables) clips or some other form of loose joinery is used to accommodate wood movement. Is this type of attachment necessary for a top this size or can I just attach it with screws?
I’ve made some bookcases where I joined the top with screws (no glue) and have not seen any problems so far.
Thanks!
-- Todd, Huntsville, AL
8 replies so far
View bladeburner's profile
bladeburner
88 posts in 3082 days
#1 posted 01-23-2014 07:08 PM
I make it a habit to always let panels move if they ever want to! For small tops like nightstands, I’ll put a pocket screw (used to use sheet metal screws) through a slightly oversized hole. So far (50 years) so good!
View Todd's profile
Todd
#2 posted 01-23-2014 07:26 PM
Thanks Blade. On the bookshelves I built I attached with pocket screws but I didn’t enlarge the holes. I had actually thought about what you had suggested before but I didn’t know if anyone had done it that way. Thanks for the advice!
View mahdee's profile
mahdee
3883 posts in 1763 days
#3 posted 01-23-2014 07:33 PM
I think it depends on the finish you put on it. If it is say, oil- based poly, it would be like a plastic wrap on that top so humidity or lack of it as it occur, has no effect on the wood since it is covered with plastic. The expansion will occur when poly is put on and contraction when it dries. So, if the top is finished before installation, it should remain stable for as long as the finish is creating a barrier. But, probably still a good idea to allow room for movement.
-- earthartandfoods.com
View pintodeluxe's profile
pintodeluxe
5654 posts in 2809 days
#4 posted 01-23-2014 07:42 PM
A bookcase top is probably 12” wide. That would be the outer limit of a rigidly attached panel.
For 18×24” I would allow for movement.
Figure 8 fasteners are my favorite.
Oversized holes for screws work in a pinch.
View bbc557ci's profile
bbc557ci
595 posts in 2069 days
#5 posted 01-23-2014 08:06 PM
Changes in humidity…. bet it’ll move
-- Bill, central NY...no where near the "big apple"
View jcsterling's profile
jcsterling
462 posts in 3580 days
#6 posted 01-23-2014 08:47 PM
depends upon the case construction as to whether you can attach solidly or with top having ability to move independent.
-- John , Central PA , www.jcsterling.com on facebook: http://www.facebook.com/#!/pages/JC-Sterling-fine-furniture/104430802928776
pintodeluxe
#7 posted 01-23-2014 08:51 PM
Regarding Mr. Jinx comments above… make no mistake wood will move, regardless of the finish applied.
I have a 42” wide dining table with breadboard ends. It is finished with stain, lacquer and wax. It shrinks about 3/8” across its width in the winter—and that is quartersawn oak. Flatsawn lumber will move even more. The problem comes when people try to stop wood from moving, because it can’t be done.
Whether the amount of wood movement will cause cracks or failed joints depends on the project.
View Todd's profile
Todd
#8 posted 01-23-2014 09:35 PM
Thanks all. I will allow for movement.
