Forstner bit over paddle bit?
Forum topic by jasonallen posted 01-23-2014 03:41 PM 863 views 0 times favorited 3 replies Add to Favorites Watch
View jasonallen's profile
jasonallen
187 posts in 1705 days
01-23-2014 03:41 PM
Topic tags/keywords: question drill press
This might be a dumb question, but what is the advantage of a Forstner bit over a regular paddle bit. I’m guessing the Forstner bit is probably sharper or holds its edge better, but I’ve never had any trouble using a paddle bit. I’m just trying to decide if I would notice a big difference if I spent the money on some Forstner bits. Thanks.
-- Skill and confidence are an unconquered army.
3 replies so far
View HerbC's profile (online now)
HerbC
1781 posts in 2944 days
#1 posted 01-23-2014 03:44 PM
1. Cuts a much cleaner hole.
2. Cuts a relatively “flat bottomed” hole with little/no lead hole.
3. Can cut a “partial” hole when used properly in a drill press.
HTH
Be Careful!
Herb
-- Herb, Florida - Here's why I close most messages with "Be Careful!" http://lumberjocks.com/HerbC/blog/17090
View dbray45's profile
dbray45
3320 posts in 2861 days
#2 posted 01-23-2014 03:49 PM
Spade bit is for roughing. Holes for wires and pipes through studs, it is fast. A forstner bit is a clean or finish hole, clean sides, clean bottom, smooth cut.
-- David in Damascus, MD
View Picklehead's profile
Picklehead
1043 posts in 2014 days
#3 posted 01-23-2014 05:55 PM
I think spade bits are so named because it looks like you dug the hole with a shovel.
-- You've got to be smarter than the tree.
