Need Help - Store bought furniture finish
Forum topic by TimberMan posted 12-26-2008 09:07 PM 1407 views 0 times favorited 7 replies Add to Favorites Watch
View TimberMan's profile
TimberMan
113 posts in 3434 days
12-26-2008 09:07 PM
Topic tags/keywords: question
I have a coffee table made by Kincade that has a dull finish (maybe Satin). My wife noticed some light scratches and tried to run them out. Now I have a few shinny spots where she rubbed. Does anyone have any advice to get the spots back down to the flat/dull finish that the rest of the table has.
I figured it was best to put the question out there before I try and screw it up more!
Thanks in advance,
Dave.
7 replies so far
View CharlesNeil's profile
CharlesNeil
2389 posts in 3840 days
#1 posted 12-27-2008 12:10 AM
sure we can help…what did she rub it with…steel wool or a compound …, may sound like the dumbest thing you ever heard of, but a light rubbing with steel wool should bring it in…if its still too glossy then we can go further down the sheen scale..by sanding with a super fine paper..but lets determine where we need to be first…knowing what she rubbed it with will help alot
TimberMan
#2 posted 12-27-2008 01:10 AM
Her finger. I was thinking that she just rubbed some of the oil from her hands on it but that does not look like the case.
CharlesNeil
#3 posted 12-27-2008 04:49 PM
try a light rub with the grain of 0000 steel wool…on an underside and see if thatgives the sheen and if not let me know if its too dull or too glossy
TimberMan
#4 posted 12-27-2008 05:56 PM
I can see fine scratches when useing the 0000. it looks like the right sheen but I don’t want scratches.
CharlesNeil
#5 posted 12-27-2008 07:16 PM
the auto compound will polish , it is a great rub out product but is designed to give a gloss….
Ok what you have is a unrubbed factory finish where the sheen is derived from using a flating paste ( silica), which causes it to appear dull…this is almost impossible to reproduce with out respraying…however the closest you will get is to use some abralon , by mirka, its basically a sandpaper sponge designed for rubbing out finishes and solid surfaces, it can be used on a random orbit sander (hook and loop)...in a 1000 grit..because it basically sands the surface to a uniform grit ,and in a random orbit pattern it doesnt show the scratches like the steel wool does…there are basically tow ways to dull a finish, first is the flating agent as described above, second is to abrade the surface in a controlled manner.( sanding) , i know this sounds dumb as a brick but it works great…to understand take a gold ring as an example, it gets dull due to small scratches gettin on it, when the jeweler buffs it , using a compound which is simply a very fine abrasive, he decreases , or removes the scratches ,which were diffusing light and made the ring appear dull, if you were to examine the ring under a magnifying glass you would see scratches…they simply arent large enough for the eye to see, what you are doing here is the reverse….you are simply sanding to a uniform ,specific grit, which will dull the surface uniformly, but you must be very careful, not to oversand, and be sure to watch for sharp edges and corners , because they can be sanded thru quickly… here is a link to but one seller of the abralon pads..
http://www.homesteadfinishing.com/htdocs/Mirkaabrasives2.htm
hope this helps…but again try it on a hidden area…1000 should give you a moderately dull finish, 500 is too course…If you need a little soapy water can help lubrication, but please go easy ..sanding thru can happen in a split second
Additionally here is a video i did on rubbing out…while you wont need to sand to level the rubout part is about the same …. http://www.antiquesbuiltdaily.com/tips.htm
hope this helps
CharlesNeil
#6 posted 12-27-2008 07:18 PM
TimberMan
#7 posted 12-27-2008 08:02 PM
Thanks for suggestions and details. I will probably try the paste wax just to see if I can get a unifor sheen and if not then lightly sand it off and recoat with a few spray coats.
BTW. the video link is still not working for me.
